Hello guys,
I am here again, with probably another issue, I hope it won't be another major one...
So, I am now talking about my Kitamura BBT30 machine, I am currently running a job, which I normally run on my Robodrill, and it runs fine although there are minor chattering problems on radiuses on the outer profile nothing too drastic, I am now running the same job on the Kitamura, and it seems that it just can't do it, I had to half the depth of cut to obtain something reasonable...
Now, although there could be something wrong with my setup, I think there could be also something wrong with the spindle maybe?
I had the spindle rebuilt and balanced 6 months ago, I tried today to put a dti , there is maybe 0.0001" or less on the spindle taper, the finish of the parts is very good, on both faces and side milling.
I have also tried to put the dti on the actual tool, about 2.5" gauge line, and if I push hard I can get 0.001" deflection, on another test on another tool holder , if I push it, it seems like there is about 0.0003" ""permanent"" move.
On top of this, at speeds above 6000 rpm, there is a light but annoying whistling noise coming from the spindle.
Thanks in advance
Thanks in advance
