Had a guy just goof cutting some material down for a lathe and wondering what to do. 1.75" diam 6061. Should be 42" which already has a little stick out. He cut em to 48". This would be 6" past the hydraulic unit bore, which is actually about .200 bigger in diam than the actual spindle liner or draw tube in this case, which is inset about 7".
This is max capacity in the lathe so actually just rides the draw tube. So figure about 13" sticking out past the draw tube. I am temped to just find something to eat up the space inside the hydraulic unit bore so there would only be about 6" sticking out.
I think we run that program maxed at 3500.
What can we get away with here? If I cut it down more, we lose material in another slug.
