Spindle Mounting Flange on a Cat40 Spindle Cartidge
Results 1 to 10 of 10
    Sep 2018
    14
    9
    Default Spindle Mounting Flange on a Cat40 Spindle Cartidge
    Hello All,
    I was cleaning my machine the other night and I noticed that my spindle mounting flange has 6 bolts that are used for mounting, and 6 set screws. Does anyone's machine also have this that would be able to tell me what the set screws are for?
    Big Plus spindle, CAT40, Milltronics VM20IL (Essentially a 4020)
    Sincerely,
    Praxis
    Oct 2009
    Oregon
    4,880
    5286
    2514
    Set screws to draw the cartridge out.
    Jan 2014
    Washington
    5,189
    933
    2815
    Quote Originally Posted by Garwood View Post
    I've seen spindles with two jack screw holes, maybe one with 3, but never one with 6. Seems like way overkill if that's the purpose.
  4. Likes Garwood, Ox liked this post
    Sep 2018
    14
    9
    I would agree that 6 holes would seem like overkill. 2 or 4 make the most sense.
    Jan 2014
    Washington
    5,189
    933
    2815
    Any chance the builder is intending the screws to be used to "tram" in the spindle?
  7. Likes Ox liked this post
  8. #6
    Jul 2006
    Hillsboro, New Hampshire
    9,268
    2193
    6429
    If so, it's a pretty crap way of doing it due to the high load contact forces. With a typical six bolt clamping I'd want at least four surrounding screws per bolt, of minimum 70% the bolt size and flat bottoms.
  9. #7
    Jan 2014
    Washington
    5,189
    933
    2815
    If so, it's a pretty crap way of doing it due to the high load contact forces........
    Yep. Shimming like done by Fadal would be preferable. Of course machining/scraping the head geometry accurately would be best of all.
  10. #8
    May 2019
    Michigan
    1,459
    420
    662
    I've seen it on an old Santec machine.
    The set screw is to keep the nut from
    coming loose. IIRC the nut was lefthand, too.
  11. #9
    Sep 2018
    14
    9
    Just thought I'd update everyone.
    After calling the manufacturer and investigating on my own, they can be used for one of two purposes. They are either plugs that keep the spindle chiller system closed, or coolant ports. In my current configuration my spindle chiller has inlet and outlet ports in the head. I suppose if you hooked up a coolant pump to it, you'd have the style where the coolant keeps the spindle cool instead of the chiller.
    Luckily it only meant me spilling 2 cups of hydraulic oil to verify....
    Thanks for everyone's reply!
    Praxis.
  12. #10
    Jul 2006
    9,268
    2193
    6429
    And thanks for the update!
  13. Likes Praxis liked this post
