Hi,
Hope someone can offer some advice. I am needing to make a 4th axis tombstone for a new product we are going to release. Need some advice on how to make it square and not bind. And perhaps I'm overthinking it.
The tombstone is 3.25x3.25" and 20" long. It will attach to the HRT-160 using the 5th Axis Rock-Lock system (we change products on our rotary often and want to stick with this system.) Opposite side supported by an A-frame.
I am worried about getting the end that connects to the Rotary Table square enough so the hole on the opposite side at the A-frame doesn't have runout relative to the centerline of the rotary. In other words, my worry is if you were just to attach the tombstone to the 4th axis that there would be runout on the opposite side, and the A-frame would try to "pull" it straight, potentially causing binding. Or maybe at that length there will be enough flex in the system so not as to worry about it?
My plan is to mill the ends first (the Rock Lock features and the hole for the A-frame) and then face each side of the tombstone once it's set up so it's square with the table. Unless others have a better idea.
What would be a good strategy for getting the right end square, with simple features for the Rock-Lock, and then make the 1.5" hole on the A frame and somehow locate it to be centered relative the the opposite side?
Thanks!
My machine is a Haas VF4-SS.
Thanks!
