Spindle nose in a coolant lake
Results 1 to 19 of 19
    Nov 2007
    Hamilton, Ontario
    1,172
    844
    443
    Default Spindle nose in a coolant lake
    I have a job coming up that I am going to have to cut a 6" deep depression in a part sort of like a bathroom sink shape but bigger and with no drain in the bottom. To avoid crazy long endmills or toolholders I was planning on having the spindle nose go down into the part. I often do this with our routers on wood patterns, I model the nose as part of the toolholder for simulation to ensure I don't get any collisions.
    It occurred to me this week that the nose will be running in coolant if I do this. Hopefully just the toolholder but maybe the actual nose of the machining center. Its a high speed spindle 24000rpm. Is running in the coolant going to cause bearing issues? Or will the toolholder act as an impeller and keep the coolant away from the nose? I will have hours of surfacing.
    I am also concerned about clearing the chips I suspect the coolant spray is not going to do much under 5-6 inches of coolant. any suggestions for clearing chips in this situation? Material is 6061 so I don't want to try running dry.
    Jun 2008
    61
    14
    22
    not sure if any damage could occur but perhaps mist would be the best of both worlds
    Aug 2008
    Paso Robles, CA
    163
    51
    23
    Can you setup an auxiliary pump or siphon to clear the coolant / chips? Or turn off the coolant manually once you have it an inch deep (or however long your tool is).
    Jul 2006
    Hillsboro, New Hampshire
    11,700
    2714
    8163
    If it was me, I'd be asking myself which would cost me more:
    1) Slowing down the spindle speed and using a longer tool and holder, setting me back a couple cutting hours.
    or
    2) Potentially losing spindle life if the lower bearings are compromised, therefore needing to replace the spindle (at a cost of $10K or so, and days of downtime) sooner than I'd hoped.
    I think I'd go with #1.
    What I'd really do is put it on the horizontal.....
  5. Likes awander, BT Fabrication liked this post
    Sep 2015
    Ohio
    1,480
    994
    1483
    I’d be more worried about all the chips you’ll be recutting and having to finish the cavity a second time to get rid of the funkiness.
  7. Likes Mtndew liked this post
  8. #6
    Jan 2019
    Arizona
    1,188
    107
    473
    Quote Originally Posted by Pattnmaker View Post
    you wont hurt the spindle, but at 24k your going to have a mist so thick you can cut it with a knife.
    I'm running a hog out 12k with endmill that barely clears the part. but coolant hits the spindle alot. running a mist buster on one machine nothing on the other. mist was really bad. it builds up bad in your chest and your going to be congested for a week after.
    I ran 2 fans out the bay door and shut the a/c system off as it made that a/c system pretty f'n gummy.
    at 24k you might throw it off balance but I dont know.
  9. #7
    Jan 2003
    495
    94
    151
    As long as the spindle is turning, I dont think you will have to worry about a lake!
  10. #8
    Dec 2019
    Utah
    34
    8
    12
    Quote Originally Posted by Booze Daily View Post
    For that I would put a couple breaks in the program to blow out the chips.
  11. #9
    Jul 2006
    11,700
    2714
    8163
    The more I think about this, the more I agree with the idea of having a way to pump out the cavity as you're working on it.
    It'll require some extra work and program breaks to reposition the pickup, but roughing and semi-finishing in a "layer cake" manner, and doing each layer as a half-n-half (cut the front, with the pickup at the back, stop program and move the pickup so the back half can be machined) should work.
    Use something like a solids-rated sump pump, so that it'll take chips and such going through it, and just dump the outlet over the side of the table. Anchor it so it won't move, find some combination of automotive radiator hoses to give you a formed shape for pickup and discharge, and you're set.
    Once you've semi-finished, go ahead and finish as one program, no pump. By that time, the chips will be small enough that there shouldn't be much of a hit from recutting on the endmills or surface finish. Maybe this would be time to use a mist rather than flood coolant.
    I would NOT cut into a lake. Just doesn't feel right. And I agree with wanting a good mist filter, you don't want to breathe that stuff or get it all over the building.
  12. #10
    Nov 2007
    Hamilton, Ontario
    1,172
    844
    443
    Now the weather is getting colder a mist filter is getting ordered soon. I like the idea of a pump. Recurring chips is definitely a concern. I had been thinking about feed holds and blowing them out but pumping coolant and hopefully chips would be good.
    I wonder if a venturi pump would work. Not sure I want a submersible pump in the the hole. Maybe a shop vac with a pump in the vac.
  13. #11
    Jul 2006
    11,700
    2714
    8163
    No pump in the hole, figure out what radiator hose could be adapted (or use regular hose and a few angle fittings) to go from table mounted pump into the hole.
    You want a good pump that will run hours and hours on end, not usually something shop vacs do. That's why I think a good quality sump-solids pump would be a good choice.
  14. #12
    Oct 2017
    960
    282
    292
    How big is your air compressor? I feel like ours would keep a sink empty by blowing on it.
  15. #13
    Sep 2015
    552
    23
    239
    Set up a pump to spray a high pressure jet of coolant into one side of the cavity. If it’s bowl shaped it will flush it right out the other side. And as a bonus, it will carry the chips out with it.
  16. Likes pb1 liked this post
  17. #14
    Jul 2006
    11,700
    2714
    8163
    Quote Originally Posted by Spruewell View Post
    My understanding of the size of the cavity in the OP's description makes me think it's going to take an almighty jet of coolant to keep it reasonably clear. Though the combination of jets and pumping would be best to get chips out.
  18. #15
    Oct 2005
    20,107
    Maybe just a shop vac with a 55 gallon drum in line with the hose.
    Set it up on a stand of some sorts, weld a 1" npt bung on the side near the bottom, so you
    can gravity it back to your coolant sump every 10 minutes or so. (yes, you'll need to stop the shop vac
    for this)
  19. #16
    Dec 2012
    Se Ma USA
    1,903
    152
    1036
    Do not breath the mist. I have 2 of these on my mill and will not run it without them. Even on low RPM jobs. My coolant pump is 13 gal/min and the splashing makes enough mist that I can feel the congestion the next day. With these running that problem goes away. The mist on low RPM jobs is very hard to see, but it is there and the intake filters on the collectors def show it.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
  20. #17
    Feb 2008
    MI, USA
    920
    70
    379
    Just put a bucket of coolant on your table and see what happens when you stick a tool down in it.
    At least you will know approximately what to expect in advance.
    I'd say get a little bit longer of a toolholder, maybe an inch longer than what you have. I doubt you'd have to change much if it is a tad longer.
  21. #18
    Nov 2019
    CANADA
    Ontario
    362
    496
    74
    id be running mist/air blast or on a horizontal.
    flooded coolant with a submerged spindle isn't a good idea.
    last resort is an extended tool holder and lighter cuts.
  22. #19
    Jun 2011
    New Jersey
    1,340
    750
    562
    I would avoid submerging the spindle nose at all costs. Many machines have breather holes and the spindles aren't really meant to work that way. Pulling coolant up into the spindle bearings means a rebuild.
  23. Likes Hardplates liked this post
