Spindle rotates only clockwise (M3 works, but M4 does not work)
Results 1 to 7 of 7
    Jun 2019
    Michigan
    Default Spindle rotates only clockwise (M3 works, but M4 does not work)
    Dear guys,
    I have a Fanuc turning machine, Oi mate TC.
    The spindle rotates CW when I run S300 M3. But it does not rotate when I run S300 M4.
    So the spindle only rotates clockwise and it does not rotate counter clockwise.
    I checked the (M3 and M4) contactor. It works when running M3 and M4 but the motor only response to M3.
    Any suggestions?
    Dec 2014
    Michigan
    764
    Check parameter 3706 bit 6(CWM) and bit 7(TCW). I think they should both be set to zero to run the spindle either direction. I used to have to set production lathes one direction, CW or sometimes CCW depending on tooling so it could never run the wrong direction. These were dedicated machines and tooling. Daryl
  3. Likes fadi_lona_20 liked this post
    Jun 2019
    Michigan
    Default Both bits are already zero
    Quote Originally Posted by Other Brother View Post
    I checked those two parameters. Bit 6 and bit 7, both are set to zero.
    Any other suggestions to do ...
    Aug 2002
    West Unity, Ohio
    26,524
    6935
    8908
    Did this just quit werking?
    Or did you just get it?
    Call Tennessee Industrial Electronics.
    Think Snow Eh!
    Ox
    Feb 2006
    Minneapolis
    219
    9
    28
    Does the lathe use contactors for the spindle? Does the contactor pull in with the M4 command? Maybe a bad contactor or wiring or the output from the controller to the contactor is bad.
    Jan 2014
    Washington
    5,259
    948
    2888
    A typical machine trouble thread where the OP is asking for help and providing almost zero information for the folks he wants help from to work with.
    For starters.....
    Post what the machine is. Who built it and what model.
    Post up some pics of the wiring diagram for spindle control.
    Aug 2002
    West Unity, Ohio
    26,524
    6935
    8908
    Quote Originally Posted by BobM3 View Post
    I would be very leary of taking M4 advise from this guy....
    Think Snow Eh!
    Ox
