cwtoyota
Cast Iron
- Feb 11, 2010
- Washington State
I've owned this old Kuraki KV-700 VMC for several years and it has never displayed the actual spindle speed while running in any mode (Memory, MDI, Jog, etc).
I'd like to know if there is/are some parameter(s) I need to change or enter to display my actual spindle RPM.
It seems to be only a parameter or data issue because:
1) The spindle pickup is working for sure, because the spindle orient command and tool change orientation works fine.
2) The correct spindle speed is also shown by the analog meter (on the NC control panel).
3) Rigid tapping works properly too.
Here's a photo of the Program Check screen while running a program from memory. The commanded spindle speed (blue underline) is 3000 RPM, but the actual spindle speed (red underline) is zero.
These are the parameters with the heading (SPINDLE) when displayed on the CRT. They are cut/pasted here from my backup file.
Thanks for any help or suggestions with this.
Code:
N5600P10000000
N5601P00000000
N5602P00001000
N5603P10000000
N5604P00000000
N5605P00000000
N5610P0
N5611P2
N5612P0
N5613P0
N5614P0
N5615P0
N5616P0
N5617P0
N5618P0
N5619P0
N5620P0
N5621P0
N5622P0
N5623P0
N5624P0
N5625P0
N5626P0
N5627P0
N5628P0
N5631P0
N5632P0
N5633P0
N5634P0
N5635P0
N5636P0
N5637P0
N5640P0
N5641P0
N5642P0
N5643P0
N5644P0
N5645P0
N5646P0
N5647P0
N5648P0
N5680P0
N5681P0
N5682P0
N5683P0
N5691P0
N5692P0
N5693P0
N5694P0
N5695P0
N5696P0
N5697P0
N5698P0
N5701P0
N5702P0
N5703P0
N5704P0
N5705P0
N5706P0
N5707P0
N5708P0
N5721P0
N5722P0
N5723P0
N5724P0
N5725P0
N5726P0
N5727P0
N5728P0
