Earlier SL series lathes had a leveling block that mounted on the turret for leveling the machine. Not sure if the SL-25 was the same or not.
That's where the back of the draw tube is. Take that sheet metal cover off and check in there.
Might be some gunk loaded up throwing it off balance.
The chuck actuator/ extension piece/ spindle tube, is bent. No amount of leveling is going to fix it.
It will have to be disassembled, cleaned and inspected to find where it is bent or otherwise knocked out of concentricity.
Like the post earlier, it is leveled by attaching a plate to one of the tool stations on the turret. On the newer NL series that station will need to be at 12:00.
The part that is shaking is circled in red. What is this thing and should it be somewhat loose?
Asking that question tells us a bit about your knowledge of a CNC lathe. All good as everybody has to start somewhere. Lots of good answers above and I would suggest you proceed with caution. Post pics and ask questions here as you step along. Piece of plastic inside draw tube most likely has a through hole and is a spindle liner. Not sure I would use a slide hammer. Some type of penetrating lube first. Dried/oxidized coolant may have "glued" it in place if it was used as a long term single part production lathe.
With your setup, you are measuring the runout between the actuator housing and your spindle- you need to mount the indicator on the frame of the machine and measure the runout of the actuator itself.
I don’t think 5 thou would cause what you are reporting. Your measuring inside the bore, not on the face right?
So run it at various speeds working up to the 3k where you see the issue. The rattling/wobbling should be happening at 1000 rpm too, just not as violent. If it happens when you get to 3k only maybe you have some harmonic thing. Just putting your hand on it would prob change it enough to quite it down.
After some coffee-time and making a slide hammer, the hydraulic actuator is measuring about 5 thou of runout at the end. I don't know if that's acceptable or not. Here's a picture:
Notice
