spindle speed for 5mm tap
Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    Mar 2013
    Danville Virginia
    121
    37
    Default spindle speed for 5mm tap
    I am rigid tapping some 5mm holes in 6061 in blind holes to 11mm depth. No coolant, just tapping fluid on the tap and in the holes. I programmed the speed at 500, forgetting that the retract speed is twice that. It worked fine but is that too fast for safety? If I break a tap, it'll be extremely difficult to get out, given the location. I am using an Emuge Tin spiral tap in my tapping head.
    Jan 2014
    Temecula, Ca
    2,811
    1264
    3648
    you're rigid tapping in a tapping head?
    Nov 2014
    Florida
    3,625
    1515
    1716
    What machine? Sounds like maybe a Haas with 2x retract speed.... 500 is fine, depending on what you want to accomplish- never breaking a tap and getting good holes, getting more cycle time..? You could go faster probably, but if it ain't broke don't fix it....
    Jul 2006
    Hillsboro, New Hampshire
    7,369
    1738
    5123
    My experience is that TiN is not a great coating for Al work, due to the surface chemistry of the coating attracting a thin transfer of aluminum. Now you have an aluminum surface cutting the Al stock, which is not ideal. Maybe your tap lube is good enough to prevent the buildup, but I'd either use a bare tap, one that's been nitrided, or perhaps a chrome coating.
    Jan 2019
    SWEDEN
    187
    56
    21
    In Alu? You're way slow on the speed, but as above posted that's fine if the cycle time is no problem. Maybe add a Q value but for heaven's sake it's Alu, it's like cutting butter.
    If I had to care about the cycle time in that material, well, I've run stainless steel at 1000+rpm. It's not like you'll break taps due to your speed-demoney ways of going half that
    Jun 2012
    Michigan
    4,629
    4240
    2796
    Quote Originally Posted by slowmotion View Post
    It all depends on your setup, how you're holding the tap, the runout, the machine and the hole size.
    On my Brother mill, I would tap at 6,000 rpm in aluminum.
  7. Likes Tichy, 2outof3 liked this post
    Jan 2019
    SWEDEN
    187
    56
    21
    Quote Originally Posted by Mtndew View Post
    Yup, I'd go 4k rpm conservative but I'm no specialist at Alu.
  9. #8
    Mar 2013
    Danville Virginia
    121
    37
    Sorry, it's a Bilz chuck, tension/compression. Machine is a VM20. I had a feeling that coated was not the best choice for alum but it's what I had. These holes are 5" down a 4" bore and close to the wall, the tool holder barely clears radially and depth wise. I'm paranoid of breaking a tap in a very inaccessible location, reason for my question. Low volume so cycle time isn't a concern.
  10. #9
    Jun 2012
    Michigan
    4,629
    4240
    2796
    Another thing you could do if you're worried about the tap breaking is to only start the tap in the machine and finish tap it by hand.
  11. #10
    Jul 2006
    7,369
    1738
    5123
    Hell, most reliably of all just threadmill it. Makes the risk of a broken tap "zero".
  12. Likes GENERALDISARRAY liked this post
  13. #11
    Jan 2019
    SWEDEN
    187
    56
    21
    Do you tap a 1" deep or 5" deep hole?
    Either way I didn't get that from your post. 1" is 25mm. 5" is 127mm.
    With the standard Fanuc cycles I'd program G84 Q7 (in millimeters). That should make it dead sure. I can't see any reason for less than 1k rpm however.
  14. #12
    Mar 2013
    Danville Virginia
    121
    37
    Tap depth is only 11mm, the holes are located 5" down into a 4" bore, see pic. I know I'm being paranoid but the blocks I'm working on cost around $8K each. I'd rather not mess one up.
  15. #13
    Feb 2013
    Idaho
    668
    139
    717
    1000 RPM and disable the speed doubling on retract. It will cause you more hours of heartbreak than it will save over the course of a year (your mileage may vary). When I'm really concerned I use Moly-Dee (even on aluminum). That stuff is a miracle tapping fluid and you only smell like elk piss for a couple of days after using it.
  16. #14
    Oct 2019
    CANADA
    Ontario
    8
    I have one question for some of the people suggesting 1000 rpm or greater. I cut aluminum daily as i do fixtures, but I don't dare go past like 250 rpm for my 5/16-18 tap (mind you the purchaser won't spend the money on quality taps). What my question is, is how fast do you feed the tap at that high of rpm to have the tap not pull out of the tapping head? by my calculations, at 6000 rpm on a 5/16-18 tap your feed would be 333 IPM. I guess that doesn't really sound high but I don't think my machine moves that fast. I might attempt it on my next job.
  17. #15
    Feb 2013
    Madison, WI
    969
    1110
    623
    Or if it has repeat rigid tapping, he could peck tap it. But at only 11mm it shouldn't be necessary.
  18. #16
    Jun 2012
    Michigan
    4,629
    4240
    2796
    Quote Originally Posted by Benplarina View Post
    The pitch of the tap is the feedrate.
    I switched to G95 for tapping a few years ago to prevent errors and it's paid off. So if it's a 5/16-18 tap then my feed is F.05555. This allows me to change the RPM at will and not worry about having the correct IPM feedrate.
    As for the tap pulling out of the tapping head, if your tap is pulling out, then you're not holding it correctly or have the wrong type of holder.
    If you have collet holders for your machines, I suggest getting tap collets. The kind with the square in the bore for the tap to seat.
  19. #17
    Feb 2014
    Sunny South West Florida, USA
    2,770
    10464
    3194
    Well, for example, I pulled the spec on a Brother Speedio S700 and their posted max feedrate is 1181 IPM...
  20. #18
    Oct 2019
    CANADA
    Ontario
    8
    I tried it out with G84 at those speeds and feeds and it works out. I just never attempted trying it that fast, Now I know it works. Thanks.
    and I will definitely try out that G95 method if my machine will take that.
    its an odd name, Quaser, with a Fanuc Series oi-md controller on it.
  21. #19
    May 2019
    314
    78
    104
    I don't know why people are so afraid of rigid tapping. I've seen far more taps broken by hand than by machine. Every tap I've ever broken while rigid tapping has been my fault, not the machines. Wrong size tap hole, worn out tap that should have been pulled from service or a bozo move of programing the wrong federate.
    Throw some scraps in the vice and play around with them, it's amazing how fast you can rigid tap. It's also a confidence booster in your machine. I've never been to worried about broken taps as they are super simple and easy to EDM out. (Old EDM machines are super cheap on ebay) Given the design they just fall apart once the core is burnt away.
  22. #20
    Nov 2014
    Florida
    3,625
    1515
    1716
    Also, for cutting tools, especially in aluminum, the coating will slightly give you a blunt edge compared to plain HSS (ground properly of course). So for alum 'bright' or plain/bare HSS works better in alot of cases.... Zrn is good for aluminum too, but I've not seen taps with that coating.
