KevintheCrawdad
- Feb 20, 2021
Hey metalheads,
Currently in the process of attempting to repair some cast iron details that were run incorrectly. I have to re cut some areas that contain a set of 16mm dowels as well as a set of 16mm taps. I found out very quickly that the nickel rod they use to weld CI produces and extremely hard weld. Seemingly my best bet (correct me if I'm wrong)is to use a spiraling process to remove the existing stock and weld, as well as come back in for a finishing pass to size. I'm use a solid carbide, .375" relieved endmill from helical. Any quick and dirty suggestions as to feed and speed? Right now I'm treating it like hardcut. Respond with any questions in addition to response if it'll help clarify. Thanks!
