I just purchased a 3 axis Fadal 15RT with the 88HS controller. I had been looking into more of a DIY solution and so had picked up some things to run a mach3 system. Now I am wondering if it is possible to run 2 controller at the same time? I am wondering if I can throw in a 4th axis stepper motor like this: 4th Axis Hollow Shaft CNC Router Rotational A Axis Φ1MM 4 Jaw Chuck Engraving | eBay
I am using Bobcad and figured maybe if we are drip feeding both controllers and maybe it is setup where I send the same instructions to both controllers at the same time that maybe the Fadal would ignore all instructions to the 4th axis, and the Mach 3 would ignore everything to the other axis since nothing would be set up on them.
I am pretty new to this, and maybe it is a stupid question, but it would be cool to be able to add a small 4th axis for less than $3000.
