Hey guys,
I am newer to the field so as always, sorry if this is a stupid question.
What is the difference between using a spot drill versus a countersink? Could I just spot drill deep enough to spot and CS in one quick operation? Or are there reasons (geometry of the drill or whatever) that you want to spot, drill, then use specifically a countersink cutter?
Also, they advertise using countersinks for chamfering as well. Any pros/cons using a countersink to chamfer versus a standard chamfer bit?
Thanks in advance guys.
