Start with schedule 160 1" seamless tube, or solid rod ?
Page 1 of 2 12 LastLast
Results 1 to 20 of 24
    Aug 2006
    greensboro,northcarolina
    2,436
    158
    605
    Default Start with schedule 160 1" seamless tube, or solid rod ?
    Part is 304 stainless, finishes at 1.125 +/- .005 OD, .862 +.003 - 0 ID, 3.25 long, ends perpendicular to bore .002 max and ends flat within .001, bore to OD runout .0025 max. Have not got pricing on tube versus rod, so I don't know what the difference in material cost is yet. 1,500 parts. This isn't something we normally would do, so I'm not familiar with the problems with tube (runout, coincentricity, straightness). If you do this kind of thing would you go with tube or solid? BTW, tube is 1.315 OD by .815 ID nominal.
    Jul 2006
    Hillsboro, New Hampshire
    8,335
    1958
    5841
    Factor in the variability of quality on the material (304 is the A36 of the stainless world), and risks to tooling and optimized F/S. If the price can be adjusted to account for it, I'd look into getting a Carpenter or other premium stainless rod and drilling it out.
  3. Likes doug925 liked this post
    Sep 2015
    Ohio
    1,223
    796
    1224
    I’d pick 1-1/8 solid. Drop them complete.
    My experience with tubing is it sucks.
    Sep 2010
    Oklahoma City, OK
    4,690
    806
    1936
    Technically speaking, isn't that pipe? If so, it's only loosely round with some sort of axial void meant for holding fluids on the inside. Joking, kinda.
    I'd prefer drilling rods.
  6. Likes Bobw, Oldwrench liked this post
  7. #5
    Aug 2013
    Chicago, IL
    927
    643
    352
    I don’t know anything about stainless but for us 1026 tubing always seems to have these gnarly long chips that get hung up everywhere. If solid stainless is easy enough to machine I would consider drilling it out...especially if you can pipe coolant through your .862” drill!
  8. #6
    Apr 2019
    Arkansas
    1,031
    391
    374
    Go with rod and avoid the headaches.
    Sent from my Pixel 3 using Tapatalk
  9. #7
    Dec 2002
    Granville,NY,USA
    3,940
    336
    430
    I would also go with solid. I have also found that it's hard to find SS tube in stock that isn't super common. At least here in the north east. I usually get a regret from the supplier.
    An insert drill will smoke that out pretty quick
  10. Likes as9100d liked this post
  11. #8
    May 2019
    651
    183
    281
    I'm going to go against the majority here and say if its seamless I would go that route. Its obviously faster to bore a hole then to drill and bore a hole.
    On edit, your title says seamless so yeah....
  12. #9
    Apr 2019
    Arkansas
    1,031
    391
    374
    Only issue is seamless tube isn't always the same size, not perfect round, tool loads change and inserts wear funny or premature.
    At that qty I'd skip all that and bar feed / pull solid bar
  13. Likes Hardplates liked this post
  14. #10
    May 2019
    651
    183
    281
    Quote Originally Posted by as9100d View Post
    Step up from 160 to XXS which will be .599" ID and run an inserted drill down it first. Should still be faster than solid bar. Just how I would want to do it, although material price and availability in small quantity would most likely cause me to use solid anyway.
  15. Likes as9100d liked this post
  16. #11
    Apr 2019
    Arkansas
    1,031
    391
    374
    I've had issues with tube in the past, it's like cast material with inclusions that destroy inserts. Idk why
  17. Likes Hardplates liked this post
  18. #12
    May 2019
    651
    183
    281
    I've played with a fair amount of boiler tubing and seen lots of xrays. Never seen an inclusion in the tube that wasn't installed by a welder Not that they don't exist but that has been my experience. Now cheaper "pipe" and seamed stuff, yeah I wouldn't be surprised to see inclusions and hard spots.
  19. #13
    Jan 2019
    Arizona
    814
    76
    281
    We run tons of smaller 304 ss in our screw machine and miyano. its cuts like butter. but its also quality tubing and cold finish. for bigger stuff 1/2" and bigger I prefer to run as a solid seems in my experience the bigger stuff kills tooling pretty fast. worse yet if you buy tubing with scale on it
    my vote for solid
    insert drill work fantastic in 304
  20. #14
    Feb 2018
    Florida
    46
    10
    6
    I make a lot of lipped 304 bushings. My sugestion would be to find a thicker wall material with some meat on the OD/ID so you can take a nice cut. If to light a cut it becomes hell.
  21. #15
    Jan 2009
    Maine, USA
    203
    100
    92
    Cole is correct, the OP is referring to pipe not tube. There is a difference between the two in both terminology and specification.
    Based on McMaster, 1-1/4" solid rod will be about half the price of the 1" Sch 160 pipe mentioned, or 1-1/4" OD x 3/4" ID tube.
    No direct experience with 304, but if it's anything like mild steel, tube will machine much better than pipe, as Delw and Hardplates suggest.
    The SS tube on McMaster is +-0.005" OD, but not available from them in 1-1/8", which is likely reflective of other suppliers. So this looks like a job from solid either way.
  22. #16
    Nov 2013
    Utah
    4,719
    1249
    2638
    Many years ago, I fought and fought a Machined tube of 304. It was bigger than the OP's, but it was a bear. About 1/4 of the lot had to be literally forced into Tolerance post Machining. It was some schedule seamless to start. It was high quality material, and respected distributor.
    IMO Solid
    R
  23. #17
    Jul 2006
    8,335
    1958
    5841
    So RJT, after all the back and forth what are you thinking?
  24. #18
    Aug 2006
    2,436
    158
    605
    Take a variable out of the mix and go with solid.
  25. Likes kustomizer liked this post
  26. #19
    Jul 2006
    8,335
    1958
    5841
    Quote Originally Posted by RJT View Post
    Sounds like a plan. And when things go tits-up you can blame us...
  27. Likes Bobw liked this post
  28. #20
    Nov 2013
    Utah
    4,719
    1249
    2638
    What just happened? Someone posted a question, got feedback, AND posted the final decision.....
    R
  29. Likes kustomizer, J Gilles liked this post
