Starting the live tooling on my Nakamura tome with Fanuc 16-TT controller.
Results 1 to 8 of 8
    May 2010
    St-Colomban,Que. Canada
    18
    Default Can't start the live tooling on my Nakamura tome with Fanuc 16-TT controller.
    Hello guys. I am making head way with my first part on this machine.Finally.
    I have been programing manually for the last ten years on Fanuc 21iT single spindle single turret .So I sorta know what I'm doing. But 2 spindles and 2 turrets with C and live tooling is all new to me.
    I am making a mushroom type bushing that needs a small hole drilled off center in the head.
    So far I have made the part in the left turret and have transferred to the right. So far so good.
    But now I can't switch the live tool motor on with code. There is an M91 for the C axis on and M 41 off. But no M code for Live?
    The book Tells me. Example
    M98 P9000 ( sub program call for cf unit engaging)
    T0505
    G97S3500M03
    And so on. Too which the controller goes into Alarm.
    I tried the Sub program.
    G28 110 M91
    m27
    g28 11-3.0 M28
    M99
    Same deal..
    There is a M88 and 89 for milling with the main spindle on, and M90 to stop it.
    What am I doing wrong here?? What does CF stand for? Sucks to be me!
    Jun 2005
    Michigan
    181
    7
    What model of nak? Sometimes right spindle codes add 400 to the standards. M441 and M491,. M488, M489 and M490
    May 2010
    18
    TW-10 model. The codes don't work on ether turret btw.
    Dec 2011
    Illinois
    263
    55
    75
    I have a book for a newer machine. It seems like M98P9000 does the same as M91, but is "To make more accurate C-axis positioning".
    Try this:
    M05
    M91
    G28H0
    G00G40G98G97T0505M88S3500
    If that doesn't work, what alarms are you getting?
    Jan 2019
    Arizona
    1,188
    107
    473
    Quote Originally Posted by NASTYZEN View Post
    T0505
    G97S3500M03
    G28 110 M91
    m27
    g28 11-3.0 M28
    M99
    Same deal..
    do you have a jog button for the turret live spindles on and off? does that work? ie one upper and one lower?
    have you tried to turn the spindle on in Jog? does it work.
    your live tooling spindle should have a separate controller I think mounted on the cabinet. is there any error codes on that?
    Aug 2016
    UNITED KINGDOM
    112
    19
    31
    We have a Mori with a 16tt control.
    Once you have engaged the C axis (On our machine M45), C axis spindle start is M13
    If we try to start the spindle with M03 when the C axis is engaged then we get an alarm.
    'Spindle start but machine not in turning mode'
    You need to include the alarm code to get the best help.
    May 2010
    18
    We have a winner!!!
    Wmpy your code works.It's alive! M88 and M89 rotation are reversed.We have live tooling rotation at last.
    Ah man I am so relieved! I had a rough night pushing buttons in my sleep..
    You guys ROCK! Thank you so much.
    Once I have machined this batch of bushings.(I think this was my last hurdle) The next ones need a square on the stem in the Z using the C. Basically turn down to .75" and then add four flats.62"x .62" x 1.16" deep on the part.
    Does anyone have a code example for this kind of simple operation?
  8. Likes wmpy liked this post
  9. #8
    Dec 2011
    Illinois
    263
    55
    75
    Nice. I'll see if I can dig up an example of milling a square.
