Starting up
Chrisp123
Apr 11, 2020
Well the time has come.... I’m going to purchase my first cnc mill. But there are too many options and after a weekend of looking my brain is mush. I’m going to be putting it in my garage so clearance is a thing. 83” to get in the door and a 102” ceiling. I was looking at fadals, and hurcos. I’d like to be under 20k if possible. Haas is pretty much out of my price range..... I saw a SWI LPN for around 20k I’m really familiar with the prototrak interface. And I love it but not familiar with the LPN just the DPM...? I need a tool changer and as much working space and travel as possible. But don’t want to break the bank...HELP!!!
Can you dig your floor down about 3 feet? A few grand in excavating and a new slab might save a lot of disappointment.
I bought the wrong CNC mill to start with (a 5k lb knee mill thing). I hated it, sold it and took a few years to figure out exactly what I needed. I'd expect it take you more than a weekend to figure this stuff out even if you're really, really smart.
The internet is pretty cool and all, but you might get a better feel for what you need if you knock on the door of a shop or three that does something similar and ask them what they use. That's what I did and I don't regret it for a second. Made some very good friends too.
Just did this, year or so ago. 20k is not going to go nearly as fas as you expect. For me, machine purchase price was about 1/3 of the total spend to get it to spit out a part.
Brace yourself.
What kind of work will you be doing? Plastics aluminum stainless?? If you like simple conversational you may want to look at milltronics. I have 2 of their old VM16s and one of their bedmills. The VM16s and VM17 are pretty inexpensive, easily well under your budget and the customer service on milltronics is some of the best I have seen. They keep info and build sheets on machines back well over 20 years. Most of the milltronics that are a little older will run off 220 single phase also.
Sent from my SM-G950U using Tapatalk
Thanks for the advice not trying to figure this out overnight. I have a pretty good idea... I’ve been a machinist for 15 years and I’ve worked in five different shops until I found a job shop that did relatively cool shit. Trying to get something going on the side for a guy that’s got me some work. Nothing too crazy but I’m gonna need to be able to hold a thou.
I will be running 4140 mostly at the start
I will look into a them worked with one at my second shop tool changer kept dropping tools.... but maybe I can find one in better shape then that one
I have worked with many of them. The one thing I have seen go bad alot are the air solenoids that are on the back, top of the control cabinet. If you have crappy air with water in the lines the oem will stick and cause alot issues like staying stuck open and dropping a tool. Electro tech mech sell a kit to replace them all pretty cheap. If you buy one and they are the original replace them. I think I paid 200 bucks for the kit. I started out with a VM16 so I could get a VMC in my garage door at my house. They are a lighter duty machine but for 6 to 8k they are the best cheapest VMCs I have seen. I started my shop 5 years ago in subdivision that had a HOA. I unloaded it wrapped up telling one neighbor it was a sauna. I had to get creative to keep nosy neighbors quiet.
I started out with a HAAS TM1, take the feet off and it will go through a normal garage door rolled on 1 inch round- lack of enclosure was a real shame, but it got me started.
Some run off single phase (mine does) which helps.
You will need at least:
tool holders - as much as you need, less than you want
tooling - 15 years in, you know what your core tools will be
vices (can get imports) - get as good as you can afford, but you can use elcheapo imports to get going
Work holding - try an auction for angle plates etc
air compressor - get as good as you can afford, ideally a screw compressor if you have ear drums
electric run to machine/compressor (big breaker - or 3 phase convertor). lighting, extra sockets - this will always cost you more than you budget
rigging - don't forget taxes etc
general Tools/coolant/oils/pins
Metrology - sky is the limit
Tool carts/tables - get twice as many as you think you need
That will take a BIG chunk out your 20k
I'm not trying to be negative, but is now really the best time to be starting up?
I will look around at the MilltRonicS machines... I really don’t want to buy a cash cow that I’m always going to be fixing up all the time. I would like to find a machine enclosed because of chips, coolant, etc. If I could find a machine I like with tooling and some bonus accessories that would be ideal. Yeah probably not the best time but the work is there right now and I wanna start making chips!!!
If you want a good cheap vise there are always auctions around. Look on bidspotter. Watch out though alot of 18% buyer premiums on the auction. If you dont have a tax sales certificate with the 18% can put you more than 25% more than the cost. If you want decent cheaper import check out shars tooling and vices. They sell on ebay cheaper than their site also.
I have only lived in two states. Maybe things are different where you are at, but how can you legally use a sales tax certificate on an item you are not going to resell?
Dualkit, in a lot of states machine tools and repair or consumable/non-consumable tooling and workholding are all tax exempt with an exemption certificate. For instance, in WI we have the S-211 form. It also includes everything from "resale" to agricultural and medical/research exemptions all on one form, so maybe his state has something similar.
Where I have been end user pays sales tax. I think food in a grocery store is the only thing exempt.
Yep pretty much the same, we just have a blanket sales tax certificate. None of our customers pay sales tax either as they are a manufacturer. We make parts that hold and fill bottles for hand sanitizers, perfumes, and fragrance mist etc etc. The end users that buy the product are the only ones to pay sales tax.
That might be the funniest story I have heard this pandemic.
That noise? oh that is the POS washing machine the wife insisted on having. Yes, she does a LOT of laundry.
Thanks cuz....
Chris P. is really my cousin. And I've been talking to him for a bit on this.
I was just typing out some advice for him on my phone, and realized that a lot of you
guys have been through this same thing, as have I. So I'm going to put my used machine
advice for him here. Its a lot easier to type on a keyboard than it is on a phone.
Comments and advice much appreciated. Right now we are just talking about a machine, we've
already talked about the other stuff.. This is the first big step.
So.
Texts from Chris. "I don't know what to do man, I've talked to many people about this"
and "I feel like I'm always going to be fixing it up".
My reply that I didn't finish typing on the phone.
----> Take it slow, gather information, process that information, think about it a lot.
research research and do some more research.
Talk to people.
All machines break, and they all need maintenance, there is no way around that.
For me at least, a machine choice, when its my money, all comes down to parts and support.
Affordable and available parts.(this is where my thumb got sore and I went to the computer)
If its available but un-affordable, you've got a boat anchor. If the part you need isn't
available at all, you've really got a boat anchor.
Sorry Chris for airing your stuff, but the people here have the experience, they've
never really led me wrong, and some of them may seem a bit harsh, me included at times,
but they are pointing out things, and they point them out because they are things
they've dealt with. This is a good place with a lot of smart people. A lot of them
doing what you are trying to do, and a lot of them that started where you are made it grow.
I know you've wanted to do this for a long time, but it doesn't have to happen this week.
I know you want it to happen this week, I understand that, it never happens that fast.
The rigger is busy, the bank screws up, the trucking company decides that your shipment
isn't important. There is always a delay, it never happens TODAY.
You're in a good position. Find the right deal on the right machine for you.
And my big advice on that. NEVER FORCE A DEAL. If it starts to go sideways, back out.
There is not a single machine deal that I've backed out of that I have regretted.
Something better always comes along.
Replace Woman with Machine in the song.
