Need some help with machining C45 steel.
I'm using new Korloy RM4 inserts with a Smoxh holder from Cutwel.
PC5300 grade insert (universal for steel and stainless)
Running at the recommended feed/speeds
0,15mm/rev
190m/min
WOC: 40mm
DOC: 1 to 2mm
Machine: VM10i
It's not that bad of a surface finish. But you can feel the grooves with your nail.
What's the issue here?
I'm not running coolant, only air.
Workholding isn't the issue
Very short gange length holder. I tried different holder with long gauge length, same issue.
0,15mm/rev
190m/min
WOC: 40mm
DOC: 1 to 2mm
Machine: VM10i
