Sticking tooling
Results 1 to 6 of 6
    Jun 2019
    Michigan
    9
    Default Sticking tooling
    I’m posting for entertainment purposes. Today I witnessed my boss use anti seize inside a spindle to “fix” the sticking tooling. I’ve also witnessed the spindles getting ground by hand with power tools. This and another spindle have less than 50% contact with the tool, only making on the upper end.
    Oct 2005
    21,575
    Quote Originally Posted by tooltechtroy View Post
    You need Walt....but has sadly passed on.
    But IIRC his son still runs Spindle Grinding Services in you area.
    Nov 2014
    Florida
    6,245
    2485
    3096
    You say ground by hand? like taking a small nick out.. or some clown trying to "dust" up the entire spindle??!?
    Never heard of using antisieze, but on Haas mills you usually (IME) need to grease a couple pull studs every so often. Also, if you are cutting without coolant, and have no spindle chiller, it could swell from heat buildup in a long cut.
    Jun 2019
    Michigan
    9
    The majority of the spindle has been ground, not just small nicks. I have one spindle with only the top near the retention knob showing contact with bluing dye
    Oct 2005
    21,575
    I guess it wasn't done properly then eh ?
  6. Likes Bobw liked this post
    Dec 2012
    Se Ma USA
    2,194
    179
    1198
    Maybe your pull studs are torqued too tight and swelling that area of tool holder? Easier to do than you might think.
