camaro_dan67
Cast Iron
- Dec 4, 2009
- N.E. Pa.
I have a Kiwa Exel Center-4 from 1984 that I've been trying to get the tool changer working on. The tool changer uses pneumatic cylinders and solenoid valves to operate. The control has a selector dial on it to do individual functions of a tool change. The manual says that the sequence to do a tool change has to start with a z zero return then in mdi an m19 for spindle orientation. Then after that the sequence is the carousel moves right to engage in the tool, the spindle lets go of the tool, the carousel moves down indexes to the next tool, puts it back in the spindle, the spindle clamps then the carousel returns. When I try to do these functions I start with the zero return orient the spindle then when I command the carousel to move right. The carousel will move about half way over and just stop. I tried pushing and pulling on it and it seems to have pneumatic resistance. So what I'm thinking is the pneumatic valves are not working right. Does anyone have experience with these valves? Its a Joucomatic 24v dc valve. I had one apart and it looks like it uses electric solenoids at each end to open pneumatic ports which actually shifts the directional control valve. What can I do to get these valves working?
