Nerdlinger
Stainless
- Aug 10, 2013
- Chicago, IL
Hi Everyone,
Machine - Tsugami B325 Swiss with oil
Material - Annealed 41L40 (see pic)
Tool - Accutrak 64XDP cobalt straight form knurl wheel
I am setting up an old job on a new machine and wanted to review my knurling process because on the old machine I had some trouble with double tracking. We always make sure to infeed relatively fast to keep the wheels from slipping and also control the turned diameter to make sure the knurl pitch divides into it evenly.
So I called accutrak and they said for this application I should use a single bump wheel because using a double knurl can introduce double tracking as a risk. So I said fine. I got a cobalt 64 pitch straight form knurl, .250" wide. I turn the 41L40 to .438" I go into X.414 at F.010 with a G4U.5 (S1000). Everything looks good but the knurl is underformed...must be material deflection, so I end at X.398 with a pretty good form, but not "full." After 100 pcs the knurl cracks (see pic.) I slow the speed down to S300 to make sure it is tracking properly and cracks again at 100 pcs (approximately.) Accutrak suggested I slow the feed rate down to F.003. Again, it cracks around 100 pcs. I tried dropping to F.002 but double tracked, so I go to X.428F.004 and then X.398F.002. Everything looks good....until it cracks again around 100 pcs.
They said I should try some HSS wheels as they are tougher so they are on order, but does anyone have any ideas as to what's going on? I really don't think I am feeding too far because the knurl is not fully formed (see pic...I'm afraid to form it more since they are breaking!) and when I measure parts that start coming out without knurl they measure right at .438 diameter so it's not like the turning insert is wearing. I'm flooding it with oil and it is just a straight in and out form with a dwell...this shouldn't be that hard haha!
Thank you!
Thank you!
