I have a 2000ish Haas EC400 dedicated to a certain part. In part of the program we have a saw programmed to cut on the edge with a diameter offset to fine tune a measured dimension. The program below is an section of the saw cut.
G154 P1
G00 G90 X6. Y-0.8
Z8.
G01 Z7.03 F50.
G01 G41 D14 X4.297 Y-0.8
Y-2.12
Y-0.8 F200.
G40 X6. Y-0.8
G00 Z8.
As you can see, the saw cuts in the negative Y then reverses in the positive Y. My question is, when there is a cutting path that reverses in a single axis, how does the controller react to a non-zero cutter comp.
Thank you for any input you are willing to share.
G154 P1
G00 G90 X6. Y-0.8
Z8.
G01 Z7.03 F50.
Y-2.12
Y-0.8 F200.
G40 X6. Y-0.8
G00 Z8.
