I've been in this business for 26 yrs. Seven years manual and last 19 years on CNC lathes.
I always seem to have a problem holding size when using a centre.
The job I'm currently doing is 390mm long, 40 mm diameter and have to turn back 295mm
There is a journal at the tailstock end with a +/- .01 mm tolerance.
I just can't get any consistency on the diameter of this journal.
When doing chucking work the machine will hold this tolerance all day long but when working with the centre It can vary +/- .02
I'm having to come slowly down to size on each one to hit the tolerance. I've got 70 of these to do.
This is a regular job, so I'd like to bottom the problem.
I've had lots of theories about this, the current one is that the stock is stress relieving as it is machined down and is putting a side load on the centre causing the effective centre line of the machine to move slightly?
The bearings on the machine are built into the quill and were recently changed. This made no difference to the accuracy. Still had the same problem.
I've not had much experience with using centres to be honest, most of our work is chucking style.
I'll also say that everyone else has the same problem but I'm lumbered with it this time.
Be grateful if anyone can share their experience.
Cheers
Dave
Cheers
Dave
