Struggling with chatter on semi-tall profile finish pass, help! - Page 2
Results 21 to 40 of 53
  1. #21
    Mar 2011
    Geneva Illinois USA
    6,560
    2932
    2625
    Any way you can pack material like bearing balls around the work. I remember a tool maker telling me that he would pack "dog shit" around die punches to keep them from singing during sharping.
    Tom
  2. #22
    Jun 2015
    701
    231
    236
    I run my long 1/2" 3F x 2"LOC at 2000 rpm and 20 IPM which seems a happy enough spot. Maritool finisher in a sidelock.
  3. #23
    Jul 2012
    Washington
    3,411
    1391
    1512
    Since this is a repeat job I suggest getting an aluminum specific 5 fluter from Harvey for the next time you do these. They are a damn interesting end mill, pretty free cutting with a big solid core for stiffness. I have buried the 3/16"x.57" loc version pretty bad a few times and it just kept cutting, well worth trying out.
  4. Likes wheelieking71 liked this post
  5. #24
    Jul 2006
    Hillsboro, New Hampshire
    13,017
    2946
    8953
    Quote Originally Posted by TDegenhart View Post
    Tom
    This one is confusing the heck out of me - bearing balls? It sounds "exciting", but not ideal when milling a finish profile.
  6. #25
    Jul 2007
    Florida
    841
    101
    441
    If all else fails, grind a small flat on the shank and try a sidelock.
    The small inherent eccentricity in a sidelock, not to mention the variable stiffness due to how a sidelock works, may break up harmonics that cause chatter.
    Use some of the existing test pieces to work out final parameters, don't keep cutting fresh metal until you're close.
    And order some more endmills, of a few different flavors. Sometimes brand S will work better than H, or G, or...
    Oh, yeah - when was the last time you checked drawbar force on that spindle?
    I think the harmonics are in the diving board he's machining. I don't think anything he does to the tool will fix it.
    CarlBoyd
  7. Likes mhajicek, wheelieking71 liked this post
  8. #26
    Mar 2011
    Geneva Illinois USA
    6,560
    2932
    2625
    Perhaps I don't understand the problem. It sounded to me like he was trying to finish the inside of a wall, but not the outside as in a pocket. If it is a blade or similar that's finished on all sides, then this is off no value.
    The point I was trying to make is sometimes the vibration is a resonance of the work and no amount of setup will change it.
    Tom
  9. #27
    Feb 2008
    MI, USA
    994
    72
    421
    Tom
    It looks like he got something to work well enough for him.
    Still, on the same train of thought that you've started with packing with dogshit, I bet you could get it to work better if you finish the walls first, then M0. Then clamp on some custom mini "C-Clamp" on the width of the part, then have the tool come in and finish the radii at the ends of the part. You'd be adding mass to the part, changing frequencies. And I think with a larger mass up high, you'd get a fair less squealing while traveling around the ends.
    Would be annoying to have to stop at M0 but hey. It's another potential workaround.
    There's gotta be 50 different solutions to this problem.
  10. #28
    Jul 2006
    13,017
    2946
    8953
    Quote Originally Posted by dandrummerman21 View Post
    How many machinists are there? That's how many solutions exist.
    [Actually, much more of course]
    It's one of those stupid things were you could take the part, the program, the cutter, etc., and mount it in an identical second machine and it would cut fine.
    Tiny differences in bearing preload, drawbar stiffness, spindle mass - any could reshape the resonance peaks of the machine to make this a non-issue.
  11. Likes TDegenhart, Mike1974, Bobw liked this post
  12. #29
    Jul 2006
    13,017
    2946
    8953
    Tom
    The way I've imagined it is a stub sticking up from a thicker section, but I've not considered it being inside a larger block or in some other way benefiting from external supports like a BB fill. But I think I understand what you were going for now.
    We never get pictures, dang it...
  13. #30
    Jan 2013
    Gilbert, AZ
    7,199
    9553
    9263
    Quote Originally Posted by CarlBoyd View Post
    CarlBoyd
    I think you are exactly correct Carl!
    The way I've imagined it is a stub sticking up from a thicker section.
    Exactly. It is essentially a 1.112" x .312" x 1.410" tall rectangle boss.
    Of which 3 sides and all 4 rads die into the floor with a sharp inside corner. The 4th side is flush with the outside of the part.
    Then, in a subsequent OP, 80% of the whole thing goes away leaving two small "legs".
    I'll snap some pics and try to find time to post them from my lap-top. I can't post pics from the shop PC anymore. Don't know why?
  14. #31
    Aug 2002
    West Unity, Ohio
    27,357
    7761
    9551
    Quote Originally Posted by wheelieking71 View Post
    Picky customer (getting pickier). I deliver in the white. He doesn't want to see any visible evidence of steps.
    Vibratory finisher.
    Think Snow Eh!
    Ox
  15. Likes mhajicek, TDegenhart liked this post
  16. #32
    Feb 2012
    1,606
    980
    1827
    Vibratory finisher.
    Think Snow Eh!
    Ox
    Interesting. You mean throw the customer into the vibratory finisher and shake some sense into him?
  17. #33
    Mar 2017
    LATVIA
    814
    224
    471
    Quote Originally Posted by Orange Vise View Post
    "finisher" sounds kind of a more definitive end to the problem...
  18. Likes TeachMePlease, Orange Vise liked this post
  19. #34
    Jan 2010
    Gilroy CA
    4,476
    3238
    2574
    It could be the endmill. Did you try a different MA ford endmill? If the cylindrical margin is wrong or slightly too large it will cause a lot more force to be applied into the part.
    On flimsy parts I've had good luck cutting to size in say 2-3 depths and then just taking a spring pass at the bottom.
  20. Likes empwoer liked this post
  21. #35
    Aug 2006
    Cape Cod, Ma
    518
    286
    128
    I would try a rougher/finisher variable flute like this rougher/finisher variable flute end mill for aluminum I have had great results with these in skinny unsupported walls in Delrin.
  22. #36
    Jan 2013
    Gilbert, AZ
    7,199
    9553
    9263
    Quote Originally Posted by dstryr View Post
    I tried exactly that at one point Dennis. Chatter on the spring pass was deafening! It was one of those cuts that definitely wanted some chip.
    And, yes, I did swap a new tool in as a sanity check. No difference.
  23. #37
    Jan 2013
    Gilbert, AZ
    7,199
    9553
    9263
    Vibratory finisher.
    Think Snow Eh!
    Ox
    See, this is what is frustrating. He bead-blasts them!
    I have probably made them 30 times before. And I have always finished this feature in Z steps.
    Actually I just roughed to size with an 1-1/4" indexable. Parts were perfect. But, you could see those "tiger stripes".
    Ha asked me to make them go away. Even though, he makes them go completely away with zero evidence when he blasts.
    I'm not one to argue with customers though. Especially right now.
    And, double especially since he just rejected the ones I just delivered that I subbed out to a good buddy of mine because I was buried.
  24. #38
    Jan 2013
    Gilbert, AZ
    7,199
    9553
    9263
    Some pics:
  25. #39
    May 2017
    Minnesota
    1,805
    2374
    1208
    Get a media blaster and offer to perform that service too.
  26. Likes macgyver liked this post
  27. #40
    Jun 2012
    Michigan
    5,910
    5577
    3767
    Some pics:
    If you can, I'd add another operation and put the part in a vise where the back face (the side that your thumb is touching) is against the vise jaw, and the moveable jaw clamps on the 2 posts. Then skin those 2 posts. Shouldn't have any chatter that way. Is that the only trouble area?
