Hello, this is my first time to post in here. I am Japanese CNC machinist in Canada and using Fusion 360.
I really need you guys help about machining taper milling.
Top dia is 1.66" and bottom dia is 1.7" As you can see my attachments, bottom surface is flat.
In this case, which cutter should I use..? Dove tail cutter can be possible but worry about good surface finishing.
If you guys have good idea, it will be very helpful and I will become next level machinist
