I used CAM for this last lathe part I did and I don't think I used our most recent post so the code was a little generic. When I tried to input a wear value in the wear tables, the program would hang up when it hit the tool offset cancel line.
Tool is called in start of program as T0606, then after its done, there is a T0600.
Maybe a better question would be if the offset cancel needs to be there at all? I about got in trouble when I restarted from a M00 I put in and the damn control did not pick up the tool offset from above. I cannot recall, does the tool cancel have to be done before a G28 or will G28 override all that? I do NOT like extra codes in a program that are not needed on a control.
