Suggest smaller shoulder mill - Speedio
Page 1 of 2 12 LastLast
Results 1 to 20 of 29
    Jun 2015
    488
    106
    128
    Default Suggest smaller shoulder mill - Speedio
    Can anyone suggest a good smaller shoulder mill?
    I'm looking at this OSG phoenix 1" OD 3 flute
    And putting it on an M12 Maritool threaded holder
    Not for hogging, just getting features with a shoulder. I run a Mitsu WSX445 which is great, but 45 degrees.
    Comments on these threaded body cutters or brands of them? I haven't used one before. The OSG one is inserted so I imagine it would last a long time. Thanks
    Sep 2007
    Washington
    5,320
    209
    1632
    Just curious why an inserted tool like this instead of a larger stubby endmill. Since this is just finishing, I don't see why a stubby 3/4" or even 1" endmill wouldn't work, and maybe better than inserted. Sharper, more rigid than that M12 threaded piece.
    Regards.
    Mike
    Jun 2012
    Michigan
    4,988
    4549
    3003
    Sandvik Coromill 316.
    CoroMill(R) 316
  4. Likes gregormarwick liked this post
    Jun 2015
    Minnesota
    447
    8
    159
    Quote Originally Posted by Finegrain View Post
    Regards.
    Mike
    Cost man, cost. You toast a 3/4 or 1" carbide end mill and a couple of your kids won't eat for a week. You toast an insert and you buy only one six pack instead of two.
    Figuratively...
    Dave
  6. Likes Pete Deal liked this post
  7. #5
    Sep 2007
    Washington
    5,320
    209
    1632
    Quote Originally Posted by 13engines View Post
    OK, fair enough.
    Do verify that whatever shoulder mill you get makes an accurate 90* wall. The last one I tried, awhile ago, was a bit off of 90*, enough to have to make another pass with an endmill anyway to get the walls right.
    Regards.
    Mike
  8. #6
    Nov 2005
    Illinois
    2,093
    216
    1751
    Figuratively...
    Dave
    Depends on how the insert fails. Ive toasted many inserts that take out the whole body. Especially the smaller indexable tooling. I've 100% given up on indexable endmills 3/4 and under, except the screw in type.
  9. #7
    Jun 2015
    488
    106
    128
    Seems a fair option. I hadn't looked down that path as I figured the holder would not be very stubby. If Maritool made stubby two ended 3 flute end mills, I'd be more inclined 3/4" in a side lock maybe. with 3/4" LOC, that would be about 3" gauge length. The OSG threaded in would be 2.375"
    I suppose I could try this one and see how it goes. 4F double ended
    I have heard the threaded cutters don't fail nicely, but I think that was when using extensions which I'm not going to use.
  10. #8
    Nov 2005
    Illinois
    2,093
    216
    1751
    Double ended end mills are nice but have issues. Sure you save money on carbide. But you get more rejects after grinding. Handling a double ended end mill has a lot of difficulties. Very very fragile. Then if you want it coated the coater charges you a premium. Again because of the extra care needed in handling. Also you get a few more rejects in this operation, chipping. Then as a last issue is that most double ended coated end mills will not fit in my endmill holders. I make then to tight as it is and the added PVD thickness makes the shank too big.
  11. Likes DavidScott liked this post
  12. #9
    Feb 2004
    Staten Island NewYork USA
    3,805
    1129
    1849
    Figuratively...
    Dave
    I went down that same road of trying to keep square shoulders with indexables as a less expensive alternative to big expensive endmills.
    I found HSM and then a fresh tool to clean walls beats indexables. Indexables only cut so deep and while yes a worn/chipped, crunched insert can be changed on the cheap...sometimes the holder takes a beating when an inserts lets loose and then its not so cheap anymore...I have a draw full of bad bodies to prove my point.
    Its amazing how long a 3/8 endmill can live taking 7/8" DOC's at 30-40 IPM...axial cuts may only be .06-.07 but the material peels right off, great finishes, good sizes, no pounding...smooth cuts allow for lackluster holding.
    IF I needed perfect sides and base...a larger finishing endmill just lasts almost forever.
  13. Likes Mtndew, wheelieking71 liked this post
  14. #10
    Jun 2015
    488
    106
    128
    Quote Originally Posted by fmari --MariTool- View Post
    ... last issue is that most double ended coated end mills will not fit in my endmill holders. I make then to tight as it is and the added PVD thickness makes the shank too big.
    I just like the short LOC on the double ended ones. I'd be fine if they only had one end. It's nice to have them short when you don't need a long cut.
    Thanks on the last point. I did read that here recently and should have remembered.
  15. #11
    Feb 2007
    Aberdeen, UK
    3,722
    1295
    1467
    Quote Originally Posted by Mtndew View Post
    CoroMill(R) 316
    Coromill 316 is a really nice range, but they are about the most expensive of the solid carbide screw ons.
    I am using a lot of Tungaloy's TungMeister recently. I think they are a rebrand of (or at least the same interface as) Iscar's multimaster, but a kind of relaunch with more shank and cutting end options.
    Also Horn's System DG, which have some really sweet cutting high feeds.
    All of these tools would be a really good fit in a Speedio in terms of performance and convenience, maybe not so much in terms of cost...
  16. #12
    Dec 2008
    New York
    10,235
    2657
    1" dia end mill with 2.5 to 3" of flute about $300. and most people get them resharpened. cost to resharpen ? not sure i doubt it be over $100. probably much less. if not badly worn most just get end resharpened which is cheaper. obviously if you dont need flutes that long use a smaller dia mill thats cheaper
    inserts are ok but they can vary cause of dirt or damage and get runout issues and not perfectly 90 degree issues. inserts vary in size, often bigger size and more expensive, used where you need the bigger size or are roughing and thicker inserts can take more feed often 200% more
    many inserts not perfect straight, notice .001" tip bulge picture. this i believe helps with getting better finish often a mirror like finish. getting consistent mirror like finish not easy, obviously if inserts dull you stop getting the mirror finish, also rpm required to get mirror finish some cnc cannot go that fast
    inserts very much need to be made for material being machined. that is if wrong inserts they can work badly
    Attached Thumbnails Attached Thumbnails tungalloyinsert.jpg   shinyhorzhead_cropped.jpg
  17. #13
    Nov 2005
    Illinois
    2,093
    216
    1751
    Indexable will always have more error than solid carbide. Always. Too many variables and tolerance stack up.
    Yea for a 1" 4 flute with 3" loc you are talking $250.00
    1.00 dia 4 flute sqr TIALN carbide finisher 3.00 loc MariTool
    But for BT30 machines I would go with a 5/8 dia 4 flute with 2.25 loc for $80.00
    .625 dia 4 flute sqr TIALN carbide finisher 2.25 loc MariTool
    Or a 6 flute 5/8 with 1.625 loc for $74
    .625 x 1.625 x 3.5 TiAlN Coated 6 Flute Finisher - Made in USA MariTool
    These will go into our supper short 5/8 BT30 endmill holders. You will have a great side wall finish and if just used for finishing will last a long time.
  18. Likes CosmosK, eaglemike liked this post
  19. #14
    Jun 2015
    488
    106
    128
    Frank,
    I'm digging the 5/8 toolholder, nice and short. Do you know how deep the shank goes into it (CAD says 1.874")? I'm just wondering if the 3.5" OAL on them would need to get lopped off to maximize stubbiness.
    Also look good (doing more AL than steel):
    3 flute single end TiCN finisher 5/8 dia x 1.25 loc MariTool
    5/8 3 Flute Carbide End Mill SE 38 Deg Helix 1.625 LOC MariTool
    5/8 3 Flute Carbide Finisher End Mill SE 45 Deg Helix 1.5 LOC - MirrorLine MariTool (extra shiny Tom!)
    another https://www.mscdirect.com/product/details/32152407
    All these would be about 1/3 the OSG option which I think would be 600ish.
    Edit: 3" OAL with .750 LOC in the 5/8 holder looks pretty good
  20. #15
    Nov 2005
    Illinois
    2,093
    216
    1751
    Yes socket depth is 1.9". Yea if you need nice and short you can cut some of the shank off and put a flat exactly where you need it.
  21. Likes CosmosK liked this post
  22. #16
    Sep 2017
    Wisconsin
    834
    149
    451
    I love the Seco Turbo mills. I run 2-3 flute in 3/4" and 1" and then 5-7 flute in 2". 0.433" tall insert in the "12" series with two edges and a wide range of relatively inexpensive insert options for a wide range of materials.
  23. Likes CosmosK, dodgin liked this post
  24. #17
    Jun 2015
    488
    106
    128
    Quote Originally Posted by Rick Finsta View Post
    Like this one I suppose: R217.69-1225.RE-12-3AN | Secotools.com
    about 1/4" shorter than the OSG
  25. #18
    Apr 2013
    219
    106
    Cosmo,
    I'm curious about the application for a large diameter stubby mill. I know your finishing walls. Is this for finishing
    Hard materials?. I typically only use large diameter for long reach applications.
  26. #19
    Jun 2015
    488
    106
    128
    I have a 3/8 x 1.25 LOC finisher always in the carousel which is my go to, but for bottom finishing and shelves, it doesn't seem ideal. For example, this part is about 4" long finishing the shelf with the 3/8" tool. I could zip around it in a couple passes with .75" or 1". I might have to go for the .625" option. I'm not running high volumes, so just would be nice to have around thing.
  27. #20
    Mar 2013
    Oregon
    1,941
    777
    2338
    I have some pretty great experiences with the Big Kaiser FCM (Square) and FCR (Corner Radius) inserted cutters. They are Big+ short length integral holders - so a one piece affair. They are extraordinarily stable in all cutting conditions. I have one cut .2" deep doing a profile around an odd shaped part, maxing out at about .5" WOC. She eats this cut at 400IPM in series production with no issues. Surface finish is good enough that bead blasting brings it right into Class A status.
    It has quickly become my favorite indexed cutter. It has a wide variety of insert grades available, but the aluminum grade comes in that nice rainbow colored uicorn blood coating, so they last forever. Best part? Misumi sells them for $250 which is a smokin' deal, especially given that you don't need to also buy a $150 holder.
    Full Cut Mill (FCR Type Standard) | DAISHOWASEIKI | MISUMI USA
  28. Likes CosmosK, SIM liked this post
