Super long super small hole
Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    Dec 2019
    New Hampshire
    Default Super long super small hole
    Hey all,
    I have a challenge at work im trying to solve. I need to drill and ream a 2.1mm hole into copper 34mm deep. I've looked around for tooling and I cant seem to find anything that will work to those depths. I'm also nervous to spend money on tooling when this strikes me as near impossible without breaking drill bits left and right or walking off center. To add, i need to make the hole flat bottomed, and then go back with a 60degree tip drill and put an additional feature down the bottom of that hole. Would a custom tool do the job? am i dreaming here?
    thanks in advance
    Mar 2013
    NW Pa
    385
    54
    163
  3. Likes Dualkit, gkoenig liked this post
    Jun 2002
    CANADA
    British Columbia
    2,645
    2155
    Good morning cc22288:
    Two questions:
    1) Do you get to choose the grade of copper?
    If so, then I recommend C145 tellurium copper because it is super machinable especially for drilling.
    Get it from McMaster Carr.
    2) Can you make it out of two pieces silver brazed together?
    If so, I recommend drilling a start hole from each end, then wire EDM cutting the finished bore, then brazing on a cap with the countersinked stepped hole.
    It'll come out dead nuts accurate if that's what you need.
    Cheers
    Marcus
  5. Likes Colt45 liked this post
  6. #4
    Nov 2009
    Michigan USA
    1,128
    84
    236
    Gun Drill..
  7. #5
    Nov 2013
    Utah
    4,679
    1240
    2620
    Micro Carbide Drills - GUHRING
    It's not going to be easy. That link is a Drill that has the physical characteristics you need, from Guhring.
    I would probably Drill as deep as needed from one side, flip the part around Drill the smaller end, and do some fancy ID Grooving from that side.
    E
  8. #6
    Feb 2013
    Madison, WI
    1,045
    1143
    677
    As previously mentioned, go with a gun drill. I would then talk to Harvey Tool about a custom counterbore tool to bore the 2.1Ø to size and make your flat bottom.
  9. #7
    Sep 2013
    PA
    507
    240
    389
    Quote Originally Posted by cc22288 View Post
    Hey all,
    thanks in advance
    If you have thru spindle coolant nothing is impossible.
    I have a job every once in a while that I drill a 2.2 hole deeper than your requirement here in CU101. I'm using Walter-Titex drills and pecking which seems to do the trick. No noticable lead off or premature tool failure. I wouldn't want to be making hundreds or thousands of them but it works for the dozen or so I need to make every few months.
    That is a difficult hole to put in so spend the money for the right tools and pass that on to the customer who needs you to know magic to make their parts.
    I'm no help on the flat bottom part but the hole itself isn't bad.
  10. Likes PegroProX440, Ox liked this post
  11. #8
    Nov 2013
    Utah
    4,679
    1240
    2620
    FYI I disagree with Gundrilling. This is a 15:1 Ratio. It isn't crazy deep or small. 25:1 is when I start thinking Guns.
    R
  12. Likes TeachMePlease liked this post
  13. #9
    May 2019
    577
    152
    225
    Its a bit ghetto but since I don't have high pressure coolant I have in the past rigged up an el cheapo pressure washer to a gundrill in the lathe. Just remember to disconnect the hose before indexing the turret . Same should apply to any through coolant drill.
    Not going to go into mass production with a pressure washer but it beats sending the work out on short runs.
  14. Likes mmurray70, Delw, Aejgx6, Ox, pianoman8t8 liked this post
  15. #10
    Jan 2003
    363
    52
    100
    Quote Originally Posted by Hardplates View Post
    Thats awesome! Got to keep that one in mind for sure. You just plumb the regular coolant supply to the pressure washer input I guess? I can see this working great for me at times. Now onto Kijiji to look for a cheap pressure washer.... lol
  16. #11
    Jan 2019
    Arizona
    757
    66
    251
    Back in the old days and maybe even today we would have a tool grinder cut is a formed carbide reamer for this type of job. it would be perfect every time.
  17. #12
    Dec 2002
    Pacific NW
    5,138
    8
    844
    I'm with Marcus on this. See if the customer will allow tellurium copper. Then it's not a particularly difficult job.
    My challenge was .020" holes in 3/4" copper for a medical part. Customer had to get FDA approval since tellurium is slightly radioactive.
  18. #13
    May 2019
    577
    152
    225
    Quote Originally Posted by mmurray70 View Post
    Correct, depending on how long you want the pump to last you may opt to install a minimalist filtration system.
    I got the idea from someone I saw doing it on a manual machine. That was a bit insane if you ask me, he had to regear the feeds so they would go slow enough for a gun drill, and build a coolant shroud. But when I saw it I thought hell, a turning center already has all that good stuff going on, all I would have to add to mine is the high pressure go go juice.
  19. #14
    Aug 2006
    greensboro,northcarolina
    2,420
    155
    602
    For a one of a kind, drill it,then make an electrode the shape you need and sinker EDM the shape into the bottom of the hole. If you need lots of parts, buy or make a form tool.
  20. #15
    Jun 2002
    CANADA
    British Columbia
    2,645
    2155
    Good morning RJT:
    I am curious; have you had good success sinker EDM cutting copper?
    I have not, although I tried everything I could think of to make it go.
    I know it must be possible because I've successfully wire EDM cut boatloads of it, but successfully sinker cutting it has always eluded me.
    So if you have a strategy that works, I'd love to hear it!
    Cheers
    Marcus
  21. #16
    Feb 2014
    Sunny South West Florida, USA
    2,955
    10854
    3337
    R
    I'd be looking at this Crazy Drill (CrazyDrill Cool XL 20 x d-ID-Mikron Tool) for the bulk of the material removal, and then maybe a reamer to get out the last few thou to make the bottom of the hole flat (How flat is flat? Corner radius allowed?)
  22. Likes PegroProX440, litlerob1 liked this post
  23. #17
    Dec 2017
    UNITED KINGDOM
    11
    Can you find someone to spark erode this for you locally.
  24. #18
    Dec 2019
    New Hampshire
    Thanks for the advice everyone. Im going to try one the guhring drill and the helios drill by sgs and see if i have any luck.
  25. #19
    Nov 2013
    Utah
    4,679
    1240
    2620
    Just remember the priority over everything else. When drilling copper-get the chips out no matter what.
    R
  26. #20
    Jan 2009
    Ohio
    842
    191
    371
    Quote Originally Posted by RJT View Post
    Was logging in to say exactly this.
    Arc Drilling in Valley View Ohio will most likely knock this out for you.
