Let me qualify what's written below, by saying that My experience is with a vanilla Fanuc control, using Renishaw's 'inspection-plus' macros, which are stored as O9000 programs in the memory, and called via sub-programs.
In my experience, a "PROBE OPEN" alarm happens when the probe is triggered, during a "protected position" move, via the O9810 program. Meaning, the probe is in rapid Z-negative, and is triggered before it actually arrives above the part. Meaning something is wrong. Either you fat-fingered a TLO for the probe, fat-fingered the Z-work offset, the physical part is too tall, a clamp is in the way, etc...
My advice would be to rule any of the obvious things mentioned above out. Double check your setup/tools/probe's TLO to make sure everything is correct.
YMMV, as LockNut mentioned that the Doosan machines handle probing differently.
