Tape Drill Stama MC010 Fanuc OM error ps581
wojtekthx
Sep 26, 2017
hi guys
I have a problem with the MC010 Fanuc OM-A without a ladder
Axes work, spindle works (M3 AND M4 with S works good), m19 works , but when I give M6 T... then I have error PS 581 (spindlIMG_7156.jpgIMG_7165.jpgIMG_7166.jpge servo alarm) and Vardy OFF 401
please help me how to solve it, it looks like some parameters are bad
Alarms in that number range are related to a function called Custom Macro, Macro Executor, or Order Made Macro. The definition of that alarm will be determined by the machine builder which in your case is Fanuc. Unless someone here with a similar vintage Fanuc DrillMate has advice, your best source for information will be your distributor or Fanuc
Fanuc send me original parameters like my but still Alarm 581
also not works Edit mode,in the DGN 122 when switch key for edit left and right works and bit is changed 0 to 1 so its works
works every key from panel Fanuc but not Edit mode
Mdi works,Auto work,edit not works
in machine is everything write like on the photos
parameter 1 is wrong becouse when insert this parameter MDI not works
i set bit 1 and 2 to 1 and the works mdi
