Jay Fleming
Hot Rolled
- Aug 7, 2014
- Noble, OK
I'm cutting an ID thread of a custom thread form, on a slight taper. The thread is close to a stub acme on form and the inserts are topping. Total cutting edge engagement is about .150" when topping. The setup is listed below.
New Haas ST35
1.5" steel boring bar extended 4.25" from holder
DOC from .001-.005" radial
Total thread depth is about .030"
6 TPI
Threading 3.5" deep
Total part length is 5.000"
Gripped length is 1.40"
Protruding length is 3.60"
400-1200 RPM
Before the insert starts topping, it'll cut nice but starts chattering as soon as it tops. I've ran from 400 up to 1200 RPM. The chatter is noticeable at all speeds, just the frequency and interval between "bumps" changes. I've tried wrapping some amount of rubber around the part. I backed off 2 set screws on the tool block and cranked the other two. Another shop that is making a similar part for us is using a 2" bar and they have better luck and they're using the same lathe. That may be the ticket but I've got to get through these 2 parts with what I have. Every other feature is perfect but the thread is causing me to scrap parts. Any help is greatly appreciated.
New Haas ST35
6 TPI
Threading 3.5" deep
400-1200 RPM
