tapered mill bore
Results 1 to 15 of 15
    Oct 2015
    Oregon
    595
    252
    460
    Default tapered mill bore
    I have an aluminum part, has a 20mm bore thru 1.17" material.
    I'm trying to mill bore to finish size for a bushing, but the bore tapers from top to bottom.
    I'm going around twice for a spring pass.
    I'm using a 3/8 x 1-1/4loc 3 flute carbide endmill.
    I would rather not add a reamer or boring head to this but it just isn't consistent.
    What am I not thinking of?
    Sep 2021
    Ohio
    194
    71
    49
    I always roughed with a helical pass and finished with a regular pass.
    Oct 2015
    Oregon
    595
    252
    460
    I'm drilling it to 19.5mm diameter and then milling.
    Does that change anything?
    Sep 2021
    Ohio
    194
    71
    49
    Quote Originally Posted by Houndogforever View Post
    You wouldn't think so. Maybe the end of your cutter is dull?
    Sep 2005
    Dunstable, UK
    59
    28
    Worn or tapered end mill, cutter run out.Cutter pushing off
    Tony
    Sep 2021
    Ohio
    194
    71
    49
    Quote Originally Posted by Mark P. View Post
    Test it on your fingernail
    Sep 2015
    Ohio
    1,903
    1232
    2041
    When I have problems with taper like that I usually have good luck running the finisher as a helical path.
  8. Likes cgrim3, doug925 liked this post
  9. #8
    Jul 2006
    Hillsboro, New Hampshire
    14,283
    3128
    9507
    We don't know the fixturing, the specific material (aluminum covers quite a range), the toolholding, the spindle/machine configuration, the speeds/feeds you're currently using, the coolant, the cutter condition, why you're not using a larger diameter endmill, whether you could use a stub reamer/home made boring bar with an insert to set diameter, the taper amount, the tolerance you're shooting for, the phase of the moon, and whether your shop rests on ancient Indian burial grounds.
    Aside from that, I can comfortably conclude that you're running the spindle backwards. Reverse rotation to CW, and you'll be spot-on.
  10. Likes Zeuserdoo liked this post
  11. #9
    Oct 2015
    Oregon
    595
    252
    460
    I got a curt 5 inch vise clamped into an old bridgeport vise hanging off the side of a chinese copy of a bridgeport mill with a hot copy of centroid system running on a virtual Linux machine.
    I'm using an old high speed steel left hand cut, right hand spiral endmill running at 92 sfm and .012 IPT.
  12. #10
    Oct 2015
    Oregon
    595
    252
    460
    ok, so actually it is on the Speedio rotary holding a 1/2" 2-clamp raptor dovetail clamp. 6061-t651 extruded bar.
    I'm using the 3/8 end mill because going much larger and the interpolated bore starts losing shape when the actual movement ends up being a 1/8" dia circle.
    I'm using a 1-1/4 loc mill as I need to reach 1.17 thru the part.
  13. #11
    Jul 2006
    14,283
    3128
    9507
    Well there's yer problem right there - I always use 94 SFM with that setup. But watch the cutter TIR, anything less than .005" and it howls like a banshee.
  14. #12
    Jul 2006
    14,283
    3128
    9507
    More seriously, it sounds like there's a lot of "stuff" in the holding path, which means a lot of opportunity for movement. I'd ditch that 3/8" full flute endmill and use a short-flute necked EM, with a helical cut to final size.
    Something like this: 3/8"DIA. 3 Flute SE HP Carbide End Mill Necked 37 Degree Helix | eBay but of the appropriate reach. YG-1 makes a range of them, and Suncoast is a good vendor. I just grabbed that link because it was the first.
  15. #13
    Dec 2020
    Maryland
    289
    192
    64
    Quote Originally Posted by Booze Daily View Post
    ^^^^^^ this
  16. #14
    Nov 2002
    3,411
    2122
    898
    NO WONDER it is running so poorly! lol
  17. #15
    Nov 2002
    3,411
    2122
    898
    Another vote for helical interpolation for the finish path.
