boring silicone grommets
EnderDRM
Nov 13, 2012
WI USA
Does anyone have any experience with boring silicone grommets in a lathe?
I think I have the workholding down, but the problem is the tool. I used a 3/8 2 flute endmill oriented like a boring bar to get a high shear angle, but it made a nasty finish and just kind of pushed the material out of the way.
I don't know the exact type of silicone it is, but one was brown and one was yellow. The yellow one was quite a bit firmer.
It is 1.025 OD x .5 Id x .78 long and I need to bore it to .55 dia.
Any help is greatly appreciated.
Yup, drop it in liquid nitrogen. Or grind, but before you go jump on the grind wagon, understand it takes a minute to get a system down. A few or several set up pieces.
R
