Well... Funny enough I think precisely spiral taps benefit the most from peck tapping through breaking the chips.
Said this for a while now. Yeah I'm pretty much a newbie machinist and I know very few use peck tapping cycles, hell I think many don't even know they exist, but (knock on wood) I have never, literally never, broken a tap using peck tapping in a rigid holder. Not for lack of trying! I only ever break taps when for some reason I'm forced to use a floating holder!
The air/coolant solution works very well for me maybe because my internal coolant isn't very high pressure; if it was it'd probably not be needed. However, a small sleeve is very beneficial in order to concentrate the coolant flow.
1.
Also my experience is the peck cycle makes me able to tap at higher speeds more safely.
But who knows, maybe you'll break you whole machine using it
