Tapping strategies on lathes
Results 1 to 5 of 5
    Dec 2006
    CANADA
    Ontario
    982
    90
    141
    Default Tapping strategies on lathes
    So I'm quoting a lathe job, 100,500,1000, 2000, pieces. 1 3/8" 1018 bar and the part is finished at 1.5" long with a 3/4-16 threaded hole through it. Now on the low qty I am happy to drill deep enough to get a 3/4-16 spiral flute tap through the part and face off or part off the extra drilled material. This the way I always did it in the past before we had a lathe with live tooling.Once the the quantity goes up I'm thinking about all the waste and considering thread milling instead. I can't decide if the glass is half empty or full. Just looking for opinions if I should be trying a different approach than" that's how we've always done it".
    Sep 2015
    Ohio
    1,012
    579
    990
    Thread milling would take longer.
    I guess you have to weigh the cost of extra cycle time vs. cost of losing the extra matl.
    Jan 2013
    Plainfield, Indiana, USA
    1,685
    1268
    907
    How is the 'cut off' end finished? Thread chamfered?
  4. Likes Philabuster liked this post
    Sep 2009
    barcelona, spain
    2,237
    507
    1350
    Please add details.
    If you are doing the next part from the same bar, why do you need to cut off the pre-drilled section ?
    On lathes with live tools spindle-orient is usually standard.
    I think.
    So you should be able to thread into the same hole, rigid tapping.
    Without spindle-orient a floating tap holder should align to the previous threads, just pick the right depth.
    Sep 2007
    Washington
    5,078
    167
    1427
    Quote Originally Posted by hanermo View Post
    Please add details.
    If you are doing the next part from the same bar, why do you need to cut off the pre-drilled section?
    Yes, this. Run the drill through and into the next part. Spiral flute tap has, what, 2 thread pitches of taper? So that's 1/8", which is your parting tool, plus you probably are doing something on the backside, like a 1/2-1 pitch chamfer. I don't see any extra waste.
    Regards.
    Mike
