are there any code to tap 1" pipe thread hole by CNC milling machine?
1" pipe requires quite a bit of torque. So the real question is, How big is your machine and what is the material you are tapping? better off thread milling it IMO.
Thanks for the reply. I guess I should say use fly cutter to do it. I did fly cut the tapped hole say M42, but don't know how to cut pipe thread hole.
Or are there code to cut taper hole by milling?
Start a new thread and ask "How do I thread mill a 1" NPTF thread?". You will get answers then.
