Is there such a thing as an undersize tap?
Results 1 to 14 of 14
    Sep 2010
    Anchorage, Alaska, USA
    760
    345
    149
    Default Is there such a thing as an undersize tap?
    Hi guys...
    I am wondering if there are undersize taps.
    Like a h-2
    I want to tap a hole, and have to force a set screw in there.
    Can't use lock-tite as temperatures will soak at 400F +
    In Aluminum. 5/16 coarse.
    Maybe I should just take my roll tap and top it on the grinder for interference...
    Set screw goes into assembly, to remain there forever...
    I am also wondering if I salted the steel set screw, if it would real quick seize up in position.
    Mark
    Dec 2004
    San Antonio, Texas
    220
    36
    260
    Undersize taps are available. Mostly used for tough to tap materials. Rough tap with the undersize tap them finish with the full size tap.
    Aug 2007
    Idaho
    2,418
    1017
    1291
    Quote Originally Posted by snowshooze View Post
    Hi guys...
    Like a h-2
    Mark
    We have a few parts where we use a plug type roll form tap but stop short of where the screw has to go so it makes the last turn or so itself and they lock in good if you dont take them out put them back in.
  4. Likes snowshooze, TrollTuner liked this post
    May 2019
    1,911
    1056
    1228
    Hi guys...
    Like a h-2
    Mark
    Could use rockset or just regular glycerin from the drug store works well also
  6. Likes snowshooze liked this post
  7. #5
    Aug 2013
    Chicago, IL
    1,248
    892
    504
    Emugee “self-lock” taps are supposed to have some fancy shape to them that results in some sort of interference fit with the screw. I tried it once with absolutely no luck. I don’t know what but I must have been doing something wrong, so it may be worth a try.
    I believe in machinery’s handbook or somewhere I read “GH_” on taps is “Ground High” and every “_” is .0005” over nominal. So a GH3 is .0015” larger that nominal on the OD. Likewise a less-common “GL_” tap would be “Ground Low” by .0005” for every “_”. It still sounds made up but I think it’s about right. So maybe you can look for some “GL” taps. Otherwise you could probably have some made for you at a reasonable price from Regal.
    Good Luck!
  8. Likes snowshooze liked this post
  9. #6
    Sep 2010
    760
    345
    149
    Quote Originally Posted by kustomizer View Post
    Daaaaa. PERFECT!!!
    Mark
  10. #7
    Sep 2010
    760
    345
    149
    Quote Originally Posted by Hardplates View Post
    Will that make it be forever stuck?
    Interesting...
    Thanks!
    Mark
  11. #8
    Sep 2010
    760
    345
    149
    Quote Originally Posted by Nerdlinger View Post
    Good Luck!
    It get's so tangled up...
    It wasn't but a couple years ago I figured out the H sizes...
    Thanks!
    Mark
  12. #9
    Sep 2010
    760
    345
    149
    Good Luck!
    GL.... ah... the lingo...
    Thanks!
    Mark
  13. #10
    Sep 2010
    760
    345
    149
    Hey Guys...
    Thank you so much.
    I got it. We all done here...
    I knew you would come through.
    Mark
  14. #11
    May 2019
    1,911
    1056
    1228
    Interesting...
    Thanks!
    Mark
    Putting the assembly in boiling water with rockset is like heat for loctite.
    It's used on the threaded connection on guns for suppressor quick detach mounts which I have seen glow orange. I don't know what it's rated temp is but it's more than 500
  15. #12
    Feb 2013
    Idaho
    850
    192
    972
    Sounds like you solved the issue... for future readers, I have done this pretty easily using a single point thread mill. Both by sneaking up on the major diameter to get the fit, and by putting a slight taper on the program.
  16. #13
    Sep 2005
    Oakland, CA
    2,923
    531
    911
    use a regular tap and anodize without masking the thread.
  17. #14
    Aug 2005
    CT
    8,297
    448
    2188
    I don't believe it is standard off-the-shelf, but I do have a few H0 taps of different sizes and different origins ( Vermont, Emuge, Fette, OSG).
    I know I've got them from Toolbuyer's Network, who got just about everything under the sun from everywhere, but they are no longer around.
    I also have a shitton of 1/2-20 H7 which saved my butt in Inco. They are Kennametal brand on the shank, but came in a Boeing box.
    And then there are the nameless 3/8-16 H12 .....
    Nonetheless, if you need something just-a-bit-unusual, you may be able to find it readily available.
    If not, then there is always NorthAmericanTool.
