Is There a Way to Use LNS Bar Loader As Work Stop?
Results 1 to 9 of 9
    Jan 2011
    Kansas
    696
    39
    53
    Default Is There a Way to Use LNS Bar Loader As Work Stop?
    Have some 2" diameter bars around 10" long that need to be machined on both sides. Is there any way to use a LNS servo bar loader as a work stop. I haven't figured it out if there is.
    Dec 2002
    Pacific NW
    5,083
    8
    821
    Maybe not exactly your situation..... I've used a Lipe pneumatic bar feeder as a stop of sorts.
    We had repeat job, large numbers of rods, 5/8" diameter and under, needing facing on both ends. Random length to start, approx 12" length +/- 1/2", just needed facing without regard to final lengths.
    Set the bar feed air pressure very low so the bars could be pushed into spindle against the feeders pressure. Push way in, close collet. Hit cycle start to bring a turret stop up. Open collet under program control allowing rod to shoot out against stop, close collet under program control. Then the rods with their random lengths were positioned for facing ends.
    Apr 2005
    Beaverdam, Virginia
    6,796
    491
    3059
    Are the slugs going to be loaded from the front or the back?
    Sep 2015
    Ohio
    993
    562
    971
    I made an adjustable stop for my drawtube but it's a PITA for short run stuff.
    I usually caliper off a jaw to do the first side then mill oal. Then you can stop off the front to do the second side.
    Jan 2019
    Arizona
    432
    29
    146
    Quote Originally Posted by munruh View Post
    Just make a chuck chip cover that is about 12" long with a 1/2" -20 thread in the bottom For adjustment.
    Couldnt think of what they called but but they slide in the chuck to keep chips out, has a flange held by 3 screws. into the chuck
    make it a couple of thou smaller than your spindle tube.
    you really only need about 8"-10" as your chuck jaws are usually 2" in depth.
    they work great solid and very accurate.
    otherwise you could use your lns servo bar if you have a way to move it in Jog, my old autobar 400 I was able to do that. just jog the pusher rod to where I wanted it.
    Aug 2002
    West Unity, Ohio
    24,722
    4850
    7548
    Not that I know of.
    Think Snow Eh!
    Ox
    Jan 2014
    Ontario, Canada
    49
    6
    I use my LNS Quickload Servo 2 like this occasionally. I would have to check exactly where it is, but there is a menu option for it in maybe the 4th or 5th page of the main menu.
  8. Likes Ox liked this post
  9. #8
    Aug 2002
    West Unity, Ohio
    24,722
    4850
    7548
    Quote Originally Posted by lwm View Post
    So when you open the chuck - it advances to the gauge point, and then it it retracts shortly after chuck closure?
    I don't know if my S1 has that option or not?
    I doo have an S2, but it's squirreled away for now.
    I will try to remember that as a possibility on that unit for the future!
    Think Snow Eh!
    Ox
  10. #9
    Jan 2014
    Ontario, Canada
    49
    6
    That is correct. The one problem I've run into is that if the operator opens the chuck again right after he closed it he can push the part back the retract distance again. There is a bit of time lag there, so it's not quite as foolproof as a deadstop, but I still use it quite frequently.
  11. Likes Ox liked this post
