bla_bledass
- Dec 11, 2021
Hi,
What are your thoughts or experiences with dry machining? I never really tried it and only have a very theoretical book that goes into CAM compensation of the generated heat....
The usual applications for me are precision parts in alu (or other soft stuff) or stainless that in de end need to go into the cleanroom. The end application is for example semicon or medical, thus cleanliness is key. My first machining experience was with a DATRON, which was great because we were not specialized in machining (that machine is really easy to operate) and the ethanol cooling meant that parts came clean of the machine. Then there was a job where we made huge parts for semicon and everything was cut with standard coolant but cleaning afterwards needed to be very thorough.
- Did you try it? How did it effect tool wear or feed?
- How did it affect precision? I can imagine the heat is not helping you reach tolerances, especially with thin walled parts. Any examples of what could be made still? Do you air cool it to make it better or does that make warping worse?
- What percentage of the hourly machine rate do you estimate coolant is? (Does potential extra tool wear with dry machining compensate this?)
Thanks!
Thanks!
