gcodeguy
Hot Rolled
- Jun 17, 2007
- Easton, PA
Anyone thread milling a 1/4-18 NPT side port on a lathe? Thread gage that checks top and bottom of thread is good. 6-step gage that checks the I.D. diameter is too deep and has play. Part done on vertical mill has no play with the 6-step gage and gage doesn't go in as deep. Lathe part has a larger I.D. I.D also has scallops around the circumference. Sides of the threads look like they have a line at each arc endpoint that is in a straight line down the length of the thread. Side of thread looks wavy at these points.
Back story. Been programming lathes a long time. We recently started getting some lathes with Y-axis. Job before this one required two 1/8-27 NPT side ports. I've never thread milled in my life. Two people from Doosan weren't able to help. One sent me a print and the program that (supposedly) ran three 1/4-18 NPT side ports when I was trying to figure out how to program the 1/8-27 NPT side ports. I tried to run their program, but it wouldn't run. Alarmed out. AFAIC the sample program never ran a part.
Our mill guy said he swings 12 arcs for running on the vertical mills. So I tried that. We have MasterCam, but no live tooling posts for our lathes. I laid out what I hoped would work and analyzed the construction to find my arc endpoints. Yes.....trig would work, but it is so much easier using MasterCam. LOL The 1/8-27 NPT didn't look quite as nice as the ones from a mill (had those minor scallops on the I.D.), but was good enough to get through inspection.
I haven't visited a machining forum in several years, but I know there used to be several very knowledgeable guys on here. Hopefully a couple are still around and can help. Thanks.
