cuttergrinder
Hot Rolled
- Mar 16, 2007
- Salem,Ohio
I have never thread milled before we had some holes that have a shoulder down in the bottom of the hole so threading with a tap is not real convenient plus the mill I was using wont drive a 3/4-10 tap. So I found a thread milling code generator on the internet and tried threading the holes. My thread mill has a dia. of .495 so I set that as my diameter on my tool page and I programmed it using .750 as my major diameter of my thread. I just used 1 radial pass to cut the thread and it came out perfect but the thread mill didnt sound too happy. The thread size was fine. Then I programmed it with 2 radial passes and then the cutter sounded much happier but the thread was too tight. So I threaded a few more after changing the tool size .005 smaller each time but the thread is still to tight. Hre are the 2 programs.
;( Date Generated: May 18, 2020, 3:50 am PST )
;( TMU Code Engine Build Date: 041417 )
;( Input Units: inches )
;( Output Units: inches )
;( Thread Type: UN, internal thread, right hand thread, climb cut )
;( Tool Profile: Full )
;( Major Diameter: 0.750 )
;( Minor Diameter: 0.656 )
;( Number of Radial Passes: 1 )
;( Radial Pass 1: 100% )
;( Thread Depth: 0.748 )
;( Threads Per Inch: 10.0000 )
;( Number of Depth Passes: 1 )
;( Tool Number: 1 )
;( Number of Flutes: 5 )
;( Major Tool Diameter: 0.495 )
;( Surface Feet Per Minute: 400 )
;( Revolutions Per Minute: 3087 )
;( Inches Per Tooth: .001 )
;( Inches Per Minute: 15.44 )
N2 G20
N4 G80 G40 G17
N6 T1 M6
N8 G90 G54 S3087 M3
N10 G00 X0. Y0. M8
N12 G43 Z0.1 H1
N14 G90 G00 Z-0.748
N16 G91 G00 X0.0179 Y0.0019
N18 G01 G41 X0.0621 Y0.0066 F5.25 D1
N20 G03 X-0.0879 Y0.1187 Z0.025 I-0.1015 J0.0167
N22 G03 X0. Y0. Z0.1 I0.0079 J-0.1273
N24 G03 X-0.0726 Y-0.1287 Z0.025 I0.0261 J-0.0995
N26 G01 G40 X0.0625 Y0.0011
N28 G00 X0.018 Y0.0003
N30 G00 G90 Z0.1
N32 G91 G28 Z0.
N34 M30
;( Date Generated: May 18, 2020, 11:51 am PST )
;( Number of Radial Passes: 2 )
;( Radial Pass 1: 65% )
;( Radial Pass 2: 35% )
;( Tool Number: 1 )
N2 G20
N4 G80 G40 G17
N6 T1 M6
N8 G90 G54 S3087 M3
N10 G00 X0. Y0. M8
N12 G43 Z0.1 H1
N14 G90 G00 Z-0.748
N16 G91 G00 X0.018 Y0.0013
N18 G01 G41 X0.0623 Y0.0044 F4.78 D1
N20 G03 X-0.0857 Y0.1053 Z0.025 I-0.0947 J0.0104
N22 G03 X0. Y0. Z0.1 I0.0054 J-0.1109
N24 G03 X-0.0751 Y-0.1131 Z0.025 I0.0182 J-0.0936
N26 G01 G40 X0.0625 Y0.0017
N28 G00 X0.018 Y0.0005
N30 G90 G00 Z-0.748
N32 G91 G00 X0.0179 Y0.0017
N34 G01 G41 X0.0622 Y0.0058 F5.09 D1
N36 G03 X-0.0872 Y0.114 Z0.025 I-0.0992 J0.0145
N38 G03 X0. Y0. Z0.1 I0.007 J-0.1215
N40 G03 X-0.0735 Y-0.1233 Z0.025 I0.0234 J-0.0975
N42 G01 G40 X0.0625 Y0.0014
N44 G00 X0.018 Y0.0004
N46 G00 G90 Z0.1
N48 G91 G28 Z0.
N50 M30
;( Tool Number: 1 )
N2 G20
N4 G80 G40 G17
N6 T1 M6
N8 G90 G54 S3087 M3
N10 G00 X0. Y0. M8
N12 G43 Z0.1 H1
N14 G90 G00 Z-0.748
N30 G00 G90 Z0.1
N32 G91 G28 Z0.
N34 M30
;( Tool Number: 1 )
N2 G20
N4 G80 G40 G17
N6 T1 M6
N8 G90 G54 S3087 M3
N10 G00 X0. Y0. M8
N12 G43 Z0.1 H1
N14 G90 G00 Z-0.748
N30 G90 G00 Z-0.748
N46 G00 G90 Z0.1
N48 G91 G28 Z0.
N50 M30
