Kenre
Cast Iron
- Apr 25, 2007
- Melbourne Australia
Just busted 2 spiral thread taps, 3x.5mm
Going 8mm deep into a 9mm deep hole in 6061 T6. Tried straight in and out and also with 4mm pecking depth, 3mm retract.
I was able to remove both taps thankfully, and both had flutes full of swarf.
I have done 100s of these no peck with a straight 3 flute bottoming hand tap! with zero issues same setup and machine, Robodrill. Just finished the job with the same original tap.
Spiral taps i know are fragile in the reverse direction, which is when they seemed to break, but thought this would be no problem.
Are they not good in smaller sizes?
