Thread: Thread taps breaking
01-20-2021, 12:33 AM #1
Just busted 2 spiral thread taps, 3x.5mm
Going 8mm deep into a 9mm deep hole in 6061 T6. Tried straight in and out and also with 4mm pecking depth, 3mm retract.
I was able to remove both taps thankfully, and both had flutes full of swarf.
I have done 100s of these no peck with a straight 3 flute bottoming hand tap! with zero issues same setup and machine, Robodrill. Just finished the job with the same original tap.
Spiral taps i know are fragile in the reverse direction, which is when they seemed to break, but thought this would be no problem.
Are they not good in smaller sizes?
01-20-2021, 12:37 AM #2
Check your drill size. Run the biggest drill your spec will allow.
01-20-2021, 12:49 AM #3
Same drill 2.5mm Only thing i changed was the style of tap.
01-20-2021, 03:03 AM #4
Kenre liked this post
01-20-2021, 03:10 AM #5
Form tap! Just be sure to control the hole to the correct diameter...
01-20-2021, 05:27 AM #6
Milland,
Might have to locate one and give it a go. Parts have rather thin walls so not sure if the thread will show.It wont affect function but will look ugly.
I have one in 4mm, has done thousands of holes! Never in a CNC tho, only in a manual mill or cordless drill and it still lives.
I thought Spiral taps were meant to wind the swarf out! not these ones.
01-20-2021, 07:23 AM #7
pb1 liked this post
01-20-2021, 07:34 AM #8
Spiral point, or thread? Spiral point will still push the chips into the hole, spiral thread run them out of the hole.
https://www.mscdirect.com/product/details/64048333
https://www.mscdirect.com/product/details/87145629
Also, a bottoming tap is alot more likely to break if you are using it to directly thread (instead of chasing a thread to the bottom) without using a starting (taper, etc) tap. We use thread forming taps with a modified bottoming point from 0-80 to #8 all the time without issue in aluminum and brass.
01-21-2021, 05:47 AM #9
Mike, most certainly a spiral thread.
01-22-2021, 05:43 AM #10
01-22-2021, 07:41 AM #11
01-22-2021, 08:26 AM #12
Check your coolant type and concentration.
I had similar problems at one point and found that the coolant being used was not reccomended for aluminum.
Majority of the parts I make are toolsteel. Aluminum was actually something I hadent worked with for 10 years or more at the time.
I couldnt get through 3 holes without breaking taps. I was even questioning the accuracy of my machine. Changed to a coolant reccomended for aluminum (much higher lubricity) and the problems all went away.
gregormarwick liked this post
01-22-2021, 10:46 AM #13
01-23-2021, 06:03 PM #14
Lots of great advise so far! I always trouble shoot one step at a time to find the cause and break things into 3 categories- program, part and tool.
PROGRAM:
- Speed/feed
- Proper codes/sequence, coolant
- Do drill and tap locations match?
- Are drill and tap depth correct? (Is tap hitting the bottom?)
TOOL:
- Sharp/ good tap?
- Correct tap type for application? (blind hole vs. thru hole)
- Correct drill size for tap type
- Measure tap for max depth
- Tool held securely and is there run out/ wobble?
PART:
- Check hole size and depth w/ pin
- Check part if it moved
- Watch tool while single blocking
If all else fails try a different style tap like a roll tap, change brands or add a peck to the tapping cycle.
