Threading back to front question
Results 1 to 11 of 11
    Nov 2019
    Missouri
    23
    Default Threading back to front question
    Hi,
    I have a little part that i am trying to run in one operation on a doosan with live tooling. Can i thread from back to front? and have normal threads?img_1559.jpg
    Jan 2014
    Temecula, Ca
    3,055
    1337
    3972
    you'll need to reverse the spindle, otherwise they'll be left handed
    Nov 2019
    Missouri
    23
    wont reversing the spindle change my tool setup?
    Jan 2014
    Temecula, Ca
    3,055
    1337
    3972
    Quote Originally Posted by mr.greenman View Post
    ya, you'll need to turn the tool upside down
  5. Likes Ox liked this post
    Apr 2018
    3,719
    1681
    Quote Originally Posted by Larry Dickman View Post
    Can you do that with a Jap/Korean turret ? Otherwise, they make a special drop-head threading holder for reverse-rotation back side turrets. As Larry says, they are upside down, But the insert still has to be on the centerline of the part
    Nov 2019
    Missouri
    23
    thanks guys,i knew i was over thinking it. i read a couple threads and someone suggested using an id threading bar turned over.
    I think i will try that first.
    Jan 2014
    Washington
    4,833
    871
    2605
    Quote Originally Posted by EmanuelGoldstein View Post
    Can you do that with a Jap/Korean turret ? ....
    Most all can. You just switch the clamp wedge position.
  9. Likes litlerob1 liked this post
  10. #8
    Nov 2019
    Missouri
    23
    Yes it can, but the insert would set back and i would have to hang the bar out to far.
  11. #9
    Jan 2003
    373
    61
    102
    I do this all the time with no issues. My very old mazak lathe uses "right side up" tooling on the back. Normal RH threads starting close to the chuck and moving away from it. Spindle in reverse and tool right side up.
    The initial plunge is a little harder on the tool, but just program more passes then you normally do and it will work fine.
  12. Likes Matt_Maguire liked this post
  13. #10
    Aug 2002
    West Unity, Ohio
    25,684
    5989
    8268
    That would werk if you are just using a basic 60* single point insert, but not if you want to use a cresting insert.
    Trying to git a full thread all the way to the undercut on your part would be much easier with a cresting insert.
    Think Snow Eh!
    Ox
  14. #11
    Oct 2011
    West-Central Illinois, USA
    1,288
    2062
    591
    With chuck turning CCW → tool cutting away from chuck → then operator side of the part insert is upside down & from the backside of the part insert is right side up = both make right hand threads.
    Good luck,
    Matt
