LockNut
Stainless
- Jan 6, 2007
- Bergen County
Good morning all,
I have a problem with the last thread of a part being rolled over, creating a burr. Bad, Bad. This is a conical shaped thread, starting at 6.60 mm and cutting down at a 10 degree angle. It is a double lead thread. The last thread rolls over creating a rather heavy burr. Part of the process uses a rotating wire brush to help de-burr, but it does not really work well. These parts cannot be touched by hand, it is a completely automated process. This is 316L medical grade stainless steel. I am using a G92 threading cycle on a Fanuc 21i-T control.
Here is a sample of code.
G92X5.50Z-5.R1.058F1.
X5.45
X5.35
X5.25
X5.15
X5.05
X5.00
X4.95
X4.92
X4.90
X4.90
G0X10.Z1.5
G92X5.50Z-5.R1.146F1.
X5.45
X5.35
X5.25
X5.15
X5.05
X5.00
X4.95
X4.92
X4.90
X4.90
G0Z20.M9
G28U0W0M5
These parts need to fit a transparency after threading and the burr causes them to not fit. Will a G76 cycle help eliminate this burr? Can this burr be eliminated sufficiently without hand work (not possible). I need to find a way to eliminate or reduce the amount of rollover on the last thread. These are bone screws and any hanging material as such can come off in the body. Really not a good thing. I really appreciate the help I might get from all of you capable and experienced pro's out there
Thanks, Paul
X5.45
X5.35
X5.25
X5.15
X5.05
X5.00
X4.95
X4.92
X4.90
X4.90
G0X10.Z1.5
X5.45
X5.35
X5.25
X5.15
X5.05
X5.00
X4.95
X4.92
X4.90
X4.90
G0Z20.M9
G28U0W0M5
Thanks, Paul
