Threading inserts
smeboss
Apr 14, 2006
Arkansas
Hi Guys
I have a Valenite A12-VLER2 boring bar, and I would like to find some threading inserts for it. I can't even find anything on the net matching the bar and so far Walter/Valenite doesn't even show that bar.
Thanks in advance!!
Charles
Search for Kennametal Top-Notch. you'll have a lot more to choose from if this is the style you're going after. They may fit into your holder (might need to change the clamp).
I sell Walter brand tooling on a distribution level. Those tools will not be available. I am sure that Tool Flo has a cross reference sheet that can point you in the right direction from them or Kennametal.
I thought this being an inserted boring bar, it might be a cnc tool. I use it on a manual LeBlond lathe, so I thought I should post in both areas just in case.
Sorry for the confusion.
Charles
