Threading inserts
Results 1 to 8 of 8
    Apr 2006
    Arkansas
    35
    Default Threading inserts
    Hi Guys
    I have a Valenite A12-VLER2 boring bar, and I would like to find some threading inserts for it. I can't even find anything on the net matching the bar and so far Walter/Valenite doesn't even show that bar.
    Thanks in advance!!
    Charles
    Jul 2010
    northern illinois
    96
    13
    24
    Walter General Catalog 2012
    page 424, there you can try and locate the inserts.
    your welcome...
    also, call them too, they have a tech department for these types of questions
    Jan 2007
    Flushing/Flint, Michigan
    8,768
    469
    7209
    Posting the same question in two areas here ( General and CNC) is confusing...
  4. Likes digger doug liked this post
    May 2005
    Ohio
    421
    20
    119
    Search for Kennametal Top-Notch. you'll have a lot more to choose from if this is the style you're going after. They may fit into your holder (might need to change the clamp).
    May 2016
    Ohio
    591
    171
    190
    I sell Walter brand tooling on a distribution level. Those tools will not be available. I am sure that Tool Flo has a cross reference sheet that can point you in the right direction from them or Kennametal.
    Apr 2006
    Arkansas
    35
    I thought this being an inserted boring bar, it might be a cnc tool. I use it on a manual LeBlond lathe, so I thought I should post in both areas just in case.
    Sorry for the confusion.
    Charles
    Apr 2006
    Arkansas
    35
    Thanks!! I will look into Tool Flow!!
  9. #8
    Apr 2006
    Arkansas
    35
    Quote Originally Posted by bradleyk View Post
    Will do, Thanks!!
