Threadmilling NPT
Likes Likes:  0
Results 1 to 2 of 2
    Feb 2010
    somewhere in Illinois
    1,159
    139
    312
    Default Threadmilling NPT
    OK, I have a thread mill for 14 NPT. Details of the mill are 4 fl diameter .490" loc 1". Material to be cut, brass or aluminum. Any advice on speeds/feed, offset (radius), depth, etc.
    I looked on-line but found no info where I looked. I understand some tool makers supply these details but have yet to find that data.
    Thanks in advance
    Krutch
    May 2007
    Central Texas, West and North of Austin
    1,627
    178
    531
    We thread mill bunches of 1/2x14 NPT and 3/4x14 NPT in class 30 cast iron. I run a thread mill very similar to what your describing, at 2000 rpm. That's a tad slow, as it's only about 262SFM, and should be a minimum of 300 on steel, probably more like 400 on cast, and a bunch faster on aluminum. I expect 600 SFM thread milling aluminum would be conservative. A lot of it depends on your machine and setup. These parts we run are fairly large castings,on a 4th axis, and the thread mills are pretty expensive compared to end mills and such, so I wrote the programs VERY conservative. Feeds generally fall in the 10 IPM range. Again, this is really conservative, but I like to stay easy on the tooling till I can tell how well everything is gonna hold up. We started running this job a couple of years ago on a linear way CAT 40 machine, we've now installed a CAT 50 box way machine in it's place, so I'll be stepping up the feeds, probably into the 20 IPM range.
    I also take two passes. Lots of folks don't, they just bog it to it and get it done in one pass. I like a lighter finish pass, but again, this was on a linear way CAT 40 machine. And not a premium machine at that.
    So, in answer to your question, start out kind tippy toeing, and work your way up till something breaks, then back off a step.)
    I also run a lot of 1.500x12 UN threads on a thread mill. But it's inserted( 1 insert), so the feeds are a lot slower. Speeds work out about the same SFM though.
