Thru-tool coolant always better than flood?
Results 1 to 10 of 10
    Jul 2008
    finland
    99
    5
    16
    Default Thru-tool coolant always better than flood?
    I've been replacing retention knobs for face and shoulder mills to allow coolant to go through spindle. Flood coolant is currently being used in every facing and shoulder milling operation on our HMC's. Material is cast iron, case-hardening steel and stainless steel, which tend to stick to inserts. Are there any reasons NOT to use thru tool coolant?
    Nov 2018
    ALAND ISLANDS
    274
    126
    81
    Through-spindle coolant: To TSC or not to TSC
    EDIT: Gosh I didn't mean to kill the vibe... My lack of comment goes with my lack of experience, as every machine I've worked on that has TSC either doesn't get used or is 100% necessary for the operation, such as lathe stuff. Never mind an HMC. Hopefully the attached thread helps.
    Oct 2007
    SPAIN
    4,248
    181
    100
    I never did use through tool on facemills or anything that would be heavy cutting.
    #1 reason was for the BBT30 machines - pull studs are tiny and with a hole in there just makes them weaker...
    #2 reason was for the BT40 machines - pull studs are bigger but with a hole in there...
    But all machines were upgraded pumps and it was like machining with a fire hose pointing at the cutter. So not only plenty cool tool, but also no swarf there for back cutting the chips as it was all blown away.
    Jul 2008
    finland
    99
    5
    16
    Sorry to start another thread, time to learn to use the search!
    I have thought of this. However I have never heard of BT50 (the taper in our machines) pull-stud breakage even with a hole in it. It could happen during heavy roughing with an endmill but I highly doubt it is possible with facemills.
    Apr 2016
    Washington
    156
    155
    88
    Quote Originally Posted by 316head View Post
    Depending on your coolant and your setup, TSC can cause foaming of the coolant. If your tank isn’t big enough to allow enough time for settling, it can result in several problems - cavitation in your coolant pump, coolant (foam) overflowing out of your tank or machine, coolant starvation, coolant / foam being drawn out by your chip conveyor - the list goes on...
    Water quality and mineral content can also play a part in foaming...
    Aug 2002
    West Unity, Ohio
    26,572
    6989
    8947
    For 50 taper - I wouldn't worry about the strength, but 40 taper and smaller - there just aint much meat in there to use it in a roughing app.
    With that said - I just pulled a face mill off the other day - only to find a string in each of the holes, presumably pushed in from the cut.
    But I'm sure that I wasn't running TSC on that tool, so - would it have pushed a chip up there with coolant going through?
    prolly.....
    I might run TSC on an endmill, but not likely on a face mill.
    Think Snow Eh!
    Ox
    Nov 2005
    Illinois
    2,112
    217
    1793
    Quote Originally Posted by barbter View Post
    This isn't so cut and dry. One can argue in certain overload conditions the retention knob with the hole will be more resistant to cracking and then as a result breaking. Many time a crack starts in the center, if you remove the center ( like a cars driveshaft) less chance of cracking. So yes and no, hard to say.
  8. Likes Ox liked this post
  9. #8
    May 2019
    Montana
    30
    19
    18
    Regarding TSC and face mills, we have been running TSC through our face mills for years on a CAT40 Haas, and it works "ehh" for roughing. We'll run 120-150% spindle load on our VF-2ss with those face mills, and no issues with the hollow pull studs. This is in 6061 and 7075. Flood coolant works better, but sometimes it just won't reach where you need it.
    It completely sucks for finishing though. Just like anything else with TSC, when you have a face mill going 8000 RPM, the coolant just flings out radially and misses the cutting zone completely.
  10. #9
    Oct 2007
    SPAIN
    4,248
    181
    100
    Quote Originally Posted by fmari --MariTool- View Post
    True but you can also argue the other way...
  11. #10
    Jun 2012
    Michigan
    5,320
    4936
    3266
    In this line of work, there rarely is anything that is always better than something else.
    It's all situational.
  12. Likes Ox liked this post
  13. #11
    Nov 2005
    Illinois
    2,112
    217
    1793
    Sure, but I make tool holders and retention knobs for a living.
  14. #12
    Oct 2007
    SPAIN
    4,248
    181
    100
    Not taking that away from you for one second there Frank.
    But back to driveshafts - you're surely talking torsion loads here? Where pull studs are 99% tension?
    With a bit of bending if the holder gets twatted side on?
    Taking meat out the centre (holes) is related to the second moment of area, so if you take out half the volume, I believe you don't remove half the strength (only a 1/4)? I'd have to dig my books out and do some calcs as it's a few years ago now...
    So for pure strength (in tension), I feel happier with solid pullstuds purely because there's more "meat" in there so effectively their stronger "like for like".
    Predominantly talking BBT30 here of course.
    Edit: back In the day (1999) I worked at a place and we had 2 brand new VMCs lose their spindles through holders rubbing the ally components. Only a slight rub and during "steady feed" (operators were proving out so overrides would have been down knowing them both) but it broke both pull studs.
    These were solid, and looking at them they looked very crystalline, but also it looked like they had torn ie if you put them in your fingers, and twisted one end, they sheared with a bit of twist in there. Probably because the spindle was running at 12krpm both times I guess?
  15. #13
    Jan 2012
    indiana, usa
    198
    48
    I run a 4" face mill 8000 RPM in aluminum, I can't say that the TSC is hitting the inserts, but I can say that flood is not. The wind generated from the face mill makes an air curtain that prevents the flood from getting to the insert. The Ingersol face mill I use has 8 octagon inserts and each insert has a coolant hole angled to shoot the coolant on the cutting edge. It seems to help finish, it may be just helping carry the chip away, not sure. This is in a CAT 50 Mazak horizontal so I am not worried about the stud.
  16. Likes Ox liked this post
