I've got a sleeve coming up to machine, mostly pretty simple except it's made from Inconel 600 and is about 11" O.D. x 8.5 I.D. and 36" long, the customer is sending us a chunk to rough out, then we send it back for them to age harden it or something then we get it back and finish machine it. I've never cut Inconel in a CNC but I know it work hardens easy, the biggest worry is some internal grooves that are about 3/8 wide and 3/16 deep with a .06R inside corner radius and a +/- .002 dia. tolerance, these are located about 10" deep from the end of the part, is it going to be possible to rough the groove, do a semi-finish cut, check size and then take a finish cut with a standard .125 wide grooving insert? Or is it going to work harden while roughing and give problems trying to finish? The O.D. has a 3mm pitch thread too, any tips on how to thread it as far as what size cut to take and finish cut size? Any help would be great.
