Colin Heath
- Mar 11, 2017
Hello All,
I am using fusion 360 and trying to load a program from a laptop via serial cable. It loads the first 3 lines then says stopped on TNC Server status a 2 bytes have been transmitted. It then just sits there.
I am using a fusion 360 TNC155 Post and wonder if that is the issue?
Here is code it generates:
0 BEGIN PGM 1001 MM
1 BLK FORM 0.1 Z X-51 Y-26 Z-26
2 BLK FORM 0.2 X+51 Y+26 Z+0
3 TOOL DEF 1 L0 R+5
4 L Z+0 R0 F9998 M91
5 M5
6 TOOL CALL 1 Z S5000
7 M3
8 L X+56.5 Y-22.375 R0 F9998
9 L Z+15 R0 F9998
10 M8
11 L Z+5 F9998
12 L Z+0 F1000
13 CC X+55.5 Z+0
14 C X+55.5 Z-1 DR+
15 L X+50
16 L X-50
17 CC X-50 Y-18.61
18 C Y-14.845 DR-
19 L X+50
20 CC X+50 Z+0
21 C X+51 Z+0 DR-
22 L Z+5 F9998
23 L X+56.5 Y+12.625 F9998
24 L Z+0 F1000
25 CC X+55.5 Z+0
26 C X+55.5 Z-1 DR+
27 L X+50
28 L X-50
29 CC X-50 Y+16.39
30 C Y+20.155 DR-
31 L X+50
32 CC X+50 Z+0
33 C X+51 Z+0 DR-
34 L Z+15 F9998
35 M9
36 M5
37 L Z+0 R0 F9998 M91
38 M2
39 END PGM 1001 MM
I can't recall seeing BLK Form parameters in the heidenhain conversational before but then I am very new to programming.
Any help much appreciated.
I am running TNC server in FE mode as it transmits more code than ME mode. I have tried my serial port with different settings but no joy.
0 BEGIN PGM 1001 MM
3 TOOL DEF 1 L0 R+5
5 M5
7 M3
9 L Z+15 R0 F9998
10 M8
11 L Z+5 F9998
12 L Z+0 F1000
13 CC X+55.5 Z+0
14 C X+55.5 Z-1 DR+
15 L X+50
16 L X-50
17 CC X-50 Y-18.61
18 C Y-14.845 DR-
19 L X+50
20 CC X+50 Z+0
21 C X+51 Z+0 DR-
22 L Z+5 F9998
24 L Z+0 F1000
25 CC X+55.5 Z+0
26 C X+55.5 Z-1 DR+
27 L X+50
28 L X-50
29 CC X-50 Y+16.39
30 C Y+20.155 DR-
31 L X+50
32 CC X+50 Z+0
33 C X+51 Z+0 DR-
34 L Z+15 F9998
35 M9
36 M5
38 M2
39 END PGM 1001 MM
