TNC 151 Whole program doesn't download from TNC Server
Likes Likes:  0
Results 1 to 10 of 10
    Mar 2017
    UNITED KINGDOM
    35
    10
    6
    Default TNC 151 Whole program doesn't download from TNC Server
    Hello All,
    I am using fusion 360 and trying to load a program from a laptop via serial cable. It loads the first 3 lines then says stopped on TNC Server status a 2 bytes have been transmitted. It then just sits there.
    I am using a fusion 360 TNC155 Post and wonder if that is the issue?
    Here is code it generates:
    0 BEGIN PGM 1001 MM
    1 BLK FORM 0.1 Z X-51 Y-26 Z-26
    2 BLK FORM 0.2 X+51 Y+26 Z+0
    3 TOOL DEF 1 L0 R+5
    4 L Z+0 R0 F9998 M91
    5 M5
    6 TOOL CALL 1 Z S5000
    7 M3
    8 L X+56.5 Y-22.375 R0 F9998
    9 L Z+15 R0 F9998
    10 M8
    11 L Z+5 F9998
    12 L Z+0 F1000
    13 CC X+55.5 Z+0
    14 C X+55.5 Z-1 DR+
    15 L X+50
    16 L X-50
    17 CC X-50 Y-18.61
    18 C Y-14.845 DR-
    19 L X+50
    20 CC X+50 Z+0
    21 C X+51 Z+0 DR-
    22 L Z+5 F9998
    23 L X+56.5 Y+12.625 F9998
    24 L Z+0 F1000
    25 CC X+55.5 Z+0
    26 C X+55.5 Z-1 DR+
    27 L X+50
    28 L X-50
    29 CC X-50 Y+16.39
    30 C Y+20.155 DR-
    31 L X+50
    32 CC X+50 Z+0
    33 C X+51 Z+0 DR-
    34 L Z+15 F9998
    35 M9
    36 M5
    37 L Z+0 R0 F9998 M91
    38 M2
    39 END PGM 1001 MM
    I can't recall seeing BLK Form parameters in the heidenhain conversational before but then I am very new to programming.
    Any help much appreciated.
    I am running TNC server in FE mode as it transmits more code than ME mode. I have tried my serial port with different settings but no joy.
    Apr 2005
    Beaverdam, Virginia
    7,454
    704
    3518
    What brand and generation of controller are you loading the program into? My Fanucs would have stopped on line 1. A letter O that is not in parenthesis is read as a new program number.
    Sep 2002
    People's Republic
    3,341
    278
    2189
    Open the program in notepad and delete the block form blocks and see if it goes in there
    I will find my post that I deleted that from
    Sep 2002
    People's Republic
    3,341
    278
    2189
    there might be a post titled 'minimal heidenhain minimal' included in Fusion
    *caution* it contains M91 at the beginning and end which may crash your machine
    I will look for mine which I deleted them but it is at work
    Mar 2017
    LATVIA
    360
    82
    182
    which mode exactly are you using to upload the code? perhaps you're trying to drip feed it?
    there are some parameters that define end characters for lines, port setting etc on the machine side, so maybe it is just coincidence that it stopped on line 4, the control may simply have ran out of buffer space for a single line when not understanding the end of line char put there by the F360 post processor
    Jun 2015
    Colorado
    489
    1009
    172
    I have TNC server set in FE mode as well and drip feed without issue. I would delete any "TOOL DEF" line (or turn off tool comments in the post dialog options inside Fusion). My TNC 355 control will fail to upload if any tool comments are in the program.
    Were you able to try the post that I attached to the other thread you started?
    Oct 2005
    England
    3,042
    24
    693
    Code looks fine,
    Set the controls mode from FE to EXT and try that if you are using a non heidenhain program to upload , also start control uploading before sending from the PC
    Also try using the heidenhain TNC server program (you'll have to set the mode back to FE for that)
    Boris
    PS M91 in TNC terms is use the machine datum as a reference for the move rather than the set datum. has no effect on the program
    PPS <<been away for a while
    Sep 2002
    People's Republic
    3,341
    278
    2189
    code is not fine
    151 will not accept block form
    Dec 2012
    ny usa
    503
    272
    ^^^^Correct^^^^. I believe that's for the graphics on the 155.
    Jun 2015
    Colorado
    489
    1009
    172
    How are you coming along with this issue Colin?
